Collecting POST binary data not working
Does the HTTP::collect or HTTP::payload not work with binary data? I have been trying to use these while uploading an image (jpg) and it doesn’t really work.
Is there another function I should be using?
Hi David,
Did you take a look at TCP::collect and payload?
Here is a link for that
http://devcentral.f5.com/wiki/default.aspx/iRules/TCP\_\_payload.html
I hope this helps,
Bhattman
Hi David,
I hope this helps,
Bhattman
