I am trying to have the load balancer respond as the server. The POST’s that are coming in do not require any data returned, but are using the Expect: 100-Continue header. The below works and I see the transaction complete via a tcpdump, but why does the logging of the payload not work? Trying to figure out where the events stack up once taking over as the server.
[CODE]
if { [HTTP::host] eq “mycompany.com ” }{
HTTP::collect [HTTP::header “Content-Length”]
if { [HTTP::header Expect] eq “100-continue” }{
HTTP::respond 100 noserver
when HTTP_REQUEST_DATA {
log local0. “[HTTP::payload]”
[/CODE]
nitass
August 10, 2012, 7:15am
2
was http_request_data event executed? did you see blank line of log?
Yes, there is a blank log message suggesting the event did fire.
nitass
August 10, 2012, 12:18pm
4
did you see content-length header and payload in the tcpdump?
Yes, there was a content-length and a one line payload in the tcpdump
nitass
August 10, 2012, 1:16pm
6
this is my testing.
[root@ve10:Active] config b virtual bar list
virtual bar {
snat automap
pool foo
destination 172.28.19.79:80
ip protocol 6
rules myrule
profiles {
http {}
tcp {}
[root@ve10:Active] config b pool foo list
pool foo {
members 200.200.200.101:80 {}
[root@ve10:Active] config b rule myrule list
rule myrule {
if { [HTTP::host] eq "mycompany.com" }{
HTTP::collect [HTTP::header "Content-Length"]
if { [HTTP::header Expect] eq "100-continue" }{
log local0. "[HTTP::payload]"
on client
[root@centos251 ~] curl -d "this_is_post_data" http://172.28.19.79 -H "host: mycompany.com"
on bigip
[root@ve10:Active] config ssldump -Aed -nni 0.0 port 80
New TCP connection 1: 172.28.19.251(43004) <-> 172.28.19.79(80)
1344602578.5274 (0.0012) C>S
POST / HTTP/1.1
User-Agent: curl/7.15.5 (i686-redhat-linux-gnu) libcurl/7.15.5 OpenSSL/0.9.8b zlib/1.2.3 libidn/0.6.5
Accept: */*
host: mycompany.com
Content-Length: 17
Content-Type: application/x-www-form-urlencoded
this_is_post_data---------------------------------------------------------------
New TCP connection 2: 200.200.200.10(43004) <-> 200.200.200.101(80)
1344602578.5293 (0.0017) C>S
POST / HTTP/1.1
Accept: */*
host: mycompany.com
Content-Length: 17
[root@ve10:Active] config tail /var/log/ltm
Aug 10 20:42:58 local/tmm info tmm[4860]: Rule myrule : this_is_post_data
Why does your SSL Dump not show the 100 status response?
I think part of the problem is that the post data only comes after receiving the 100 response from the server, but it is not a new HTTP request.
This is what I see on a transaction:
New TCP connection 1: 4.59.146.74(60372) <-> *.*.*.*(80)
1344605329.3721 (0.0066) C>S
POST /smspostback HTTP/1.1
User-Agent: CDYNE SMSv2
Host: mycompany.com
Content-Length: 161
Expect: 100-continue
Connection: Keep-Alive
1344605329.3722 (0.0001) S>C
HTTP/1.0 100 Continue
Content-Length: 0
1344605329.3789 (0.0066) C>S
SMSSent=1&MessageID=b99b166b-559a-4a60-ad3b-ac3f0ac09c5c&ReferenceID=&FromPhoneNumber=***********&ToPhoneNumber=***********&SentTime=8%2f10%2f2012+1%3a28%3a49+PM---------------------------------------------------------------
1 1344605334.3497 (4.9708) C>S TCP FIN
1 1344605334.3498 (0.0000) S>C TCP FIN
Oh wait, the LB is responding with an HTTP/1.0 response…DOH!
This is why the below hangs…
curl -d "this_is_post_data" http://mycompany.com -H "Expect: 100-continue"
Does anyone have any ideas on where to capture the continued POST data?
nitass
August 12, 2012, 10:27am
11
what about this one?
virtual bar {
ip protocol 6
rules myrule
profiles {
http {}
tcp {}
rule myrule {
if { [HTTP::host] eq "mycompany.com" } {
if { [HTTP::header Expect] eq "100-continue" } {
HTTP::respond 200 noserver
on client
[root@centos251 ~] curl -d "this_is_post_100_data" -i http://172.28.19.79 -H "Host: mycompany.com" -H "Expect: 100-continue"
Content-Length: 0
[root@centos251 ~] curl -d "this_is_post_data" -i http://172.28.19.79 -H "Host: mycompany.com"
HTTP/1.0 200 OK
Content-Length: 0
on bigip
[root@ve10:Active] config cat /var/log/ltm
Aug 12 18:23:54 local/tmm info tmm[14353]: Rule myrule : this_is_post_100_data
Aug 12 18:24:12 local/tmm info tmm[14353]: Rule myrule : this_is_post_data
Wow, yes that worked perfectly. I never thought to put the HTTP response in the data event, but there it is…Thanks!
