How to clear IP sticky sessions via command line on F5 LTM?
tmsh delete ltm persistence persist-records
You can refine what is deleted. e.g
tmsh delete ltm persistence persist-records virtual my-virtual
Has anyone answer this question?
You can clear the connections by a simple command, You will have options to select either based on virtual server using command
If you want to delete to a the presistance for a single node, you can use command.
tmsh delete ltm persistence persist-records pool node-addr node-port
