HI Guys
I have a client who want to do distribution of client session on /20 (4096 ip treated as one for server assignment)
but he realized that in this way the persistency (set at 960 sec = 16 minutes) never expires. Since there is a limit of 35K sessions, the side effects is “session starvation”. So he would like to have distribution on /20 BUT having more granular persistency based on client IP. /32 so one record for each ip. Now my concern is the amount of records in the persistency table. could this be a problem ? how many records can an F5 manage until have CPU/Line card issues ? I already verified alternative methods to do persistency like cookies, but this doesn’t apply because the communication is encrypted from client device to server with a TLS tunnel so i can’t inject anything. this is the script. could it work of could i have usage issues ? the model is BIG-IP 17.1.1.3 Build 0.0.5 Point Release 3 the script is the following:
thank you for your help
B.R
Mario
| when CLIENT_ACCEPTED { # Persistence over IP persist uie [IP::client_addr] # Load balacing on subnet /20 set client_ip [IP::client_addr] set subnet_ip [IP::addr $client_ip mask 255.255.240.0] # Get active pool member list set active_members [active_members -list pool ] # If there are active members, pick one based on the hash of the masked IP if {[llength $active_members] > 0} { set member [lindex $active_members [expr {[crc32 $subnet_ip] % [llength $active_members]}]] pool member $member }} |
