I think some of the strings in your post were stripped. If you had text within angle brackets you can get them to render by putting spaces between the text and brackets: < text >.
In general, the receive string can be a regex. So you could use a receive string like:
(string1|string2)
Your other idea of configuring two monitor with a minimum successful count of 1 would work nicely as well.
