Centralized Application Control for Distributed AI with Equinix and F5 Distributed Cloud
As AI adoption accelerates, I’ve been seeing a common architectural pattern emerge: centralized AI factories handling model training, with inference workloads pushed out to remote departments like public safety, healthcare, or logistics. While the execution is distributed, the operational requirements—security, performance, and policy consistency—remain very much centralized.
The challenge isn’t running inference at the edge; it’s delivering centralized AI services to distributed consumers without introducing complex routing, fragmented security controls, or inconsistent performance between locations.
This article outlines how you can address that problem using F5 Distributed Cloud (XC) Customer Edge deployed on Equinix Network Edge, with private connectivity provided by Equinix Fabric.
The Problem to Solve
From an infrastructure perspective, these environments tend to stress three things simultaneously:
  • Scalability, as data volumes and inference demand grow rapidly
  • Security, to protect models, APIs, and sensitive inference data
  • Reliability, so performance remains consistent regardless of where requests originate
Traditional approaches often force tradeoffs—centralize everything and accept latency, or decentralize enforcement and deal with policy sprawl. What we need is centralized control with distributed execution.
Architectural Approach
Rather than building bespoke connectivity for each inference location, we’ll focus on creating a repeatable edge pattern that could be deployed globally while still being governed centrally.
The architecture breaks down into four core components:
Central AI Factory (Training Hub)
This is where model training and lifecycle management live. It connects to S3‑compatible object storage for large‑scale data ingestion and model artifacts. Importantly, it doesn’t need direct exposure to every inference a consumer makes.
Equinix Fabric
Equinix Fabric provides private, low‑latency connectivity between the AI factory and distributed inference locations. In this design, it effectively acts as a segment extender across regions, keeping AI traffic off the public internet while preserving predictable performance.
F5 XC Customer Edge (CE) instances are deployed close to inference consumers. These handle traffic management, API security, segmentation, and observability, while remaining under centralized policy control. This is where enforcement happens—consistently, everywhere.
Equinix Network Edge Marketplace
Equinix Network Edge enables rapid deployment of Customer Edge instances in new regions without waiting on physical infrastructure, which is critical when inference demand expands faster than traditional provisioning cycles.
How It Works
Inference requests are processed locally through CEs at each location. When access to centralized resources is required—such as model updates or validation—traffic traverses Equinix Fabric back to the AI factory.
The key detail is that policy is defined centrally but enforced at the edge. Security controls, API protections, and segmentation rules are created once and applied uniformly, regardless of geography. That eliminates the need for custom routing logic or per‑site security tuning.
Design Principles That Matter
A few principles guided the implementation:
  • Centralized control, distributed execution — inference stays close to data. Governance stays centralized
  • Zero Trust by default — all AI data flows are explicitly authenticated and authorized
  • Elastic expansion — new regions can be brought online quickly through the Marketplace
  • Integrated observability — traffic, performance, and security posture are visible across all endpoints
  • Compliance‑ready — isolation and segmentation support regulatory requirements like GDPR and HIPAA
When This Pattern Fits
This approach works well for organizations that need to scale AI inference across multiple regions or departments while maintaining tight operational control. It’s particularly effective when inference demand grows incrementally and predictability, security, and governance matter more than ad‑hoc edge autonomy.
If the goal is centralized governance with distributed execution, this pattern provides a clean and repeatable way to get there.
Additional Links
F5 Distributed Cloud Services
Equinix Fabric
