Here’s my first crack at a template for GTM (included in the archive is also the LTM template). Note that you will need to have at least 0.8.7a installed to import the templates.
You’ll notice that the global DNS graphs are line based and the wideIP graphs are stacked. There’s no reason, I just haven’t decided which I like better, so if you want to make them consistent this is done in the graph template.
That question would probably be better answered in the Cacti forums. I’m guessing that if your rate is less than 1/second and you don’t have a scaling setting set correctly that it averages you out and auto-scale prints the sub-one number. Remember that the rrd values are just stored data, the graphs utilize business rules (CDEF) to represent the delta’s for those values.
For GTM, I don’t use any CDEFs. I’m not sure how to solve the problem, except to increase your DNS hit count… For testing, you could use this script (courtesy of F5) to generate queries:
!/bin/bash
Initialize Variables
COUNT=0
LOGEVERY=10
LOGCOUNT=0
Gather Test Data
echo -n 'Enter DNS Server IP addres: ’
read DNSIP
echo -n 'Enter FQDN for resolution: ’
read FQDN
echo -n 'Enter number of resolution attempts: ’
read LIMIT
echo -n 'Specify output file: ’
read OUTFILE
Check for $OUTPUT file exists, if the file exists and IS NOT empty
clear the file with cat /dev/null to empty it out.
if [ -s $OUTFILE ]
then
echo ‘Output file $OUTFILE exists and is NOT empty… Resetting file.’
