Block keywords
Hello,
I am looking for a way to block access based on the presence of certain keywords contained within the URL. For eg:
GET /ctc/servlet/com.sap.ctc.util.ConfigServlet?param=com.sap.ctc.util.FileSystemConfig;EXECUTE_CMD;CMDLINE=
We are already blocking the pattern /CTC/.* from the Internet and internal networks using an irule, but the concern is that there may be other paths that would allow an attacker to run commands such as EXECUTE_CMD , CMDLINE etc.
Is there a way to block these keywords regardless of the URL patterns being accessed.
Thanks,
Karthik
This could be tricky, as you would have to check for valid variations (e.g. encoded) as well. A simple string-comparison would still leave room for attackers.
Would you happen to have a license for ASM? That would be the best way to cover the variations an attacker would use.
Another option would be to implement some kind of authentication mechanism.
It would be best to harden the application. A quick search for “hardening SAP” yield numerous resources (including from SAP).
You may end up having to do both (i.e. harden SAP and augment security on the BIG-IP) - depending on the version of SAP you’re running and the options it offers for security/hardening.
There’s a presentation on OWASP’s web site that seems to indicate that there are quite a few more problems than the URL commands. It’s several years old, so perhaps SAP has fixed those security issues. On the other hand, I found more recent articles that also detail security problems with SAP.
Thanks Arie. We are going to be putting up an ASM in the near future and applying relevant SAP Notes. However, in the meantime I need to quickly block these keywords and would appreciate any help in getting this done
