How to check what’s the reason for resetting connection from F5 in this situation: F5 receives from server ‘application/octet-stream’ http first packet, acknoledges it and then sends rst to client and server. When rst logging is enabled (sys db tm.rstcause.log value enable) in logs there’s no information regarding what causes reset that connection. There’s no ASM module provisioned also. Why F5 would send reset to client and then to server ? Is there another command / log switch which can show this reason ?
For the RST logging, you mentioned that it is enabled, so please check the below article for checking the statistics and an example of the log messages.
if you didn’t find any log entries regarding the issue, you can start generating a tcpdump (Packet capture) using a command like the below on bash:
tcpdump -nnnveti 0.0:nnnp host “filter by an IP” and port “add port” -s0 -S -w /var/log/pcapname.pcap
Example:
tcpdump -nnnveti 0.0:nnnp host 172.20.10.1 and port 443 -s0 -S -w /var/log/pcapname.pcap
and then the cause might be mentioned in the generated file as per the below exmaple:
I’ve checked it is reseted because “Malformed HTTP header error”. I suspect specific header but would like to be sure that it is because of that header - how to check which http header caused an error/is it possible to display such information ?
as per the below article “Beginning BIG-IP 12.0.0 HTTP profile enforces strict header checks. HTTP request or response that does not conform to RFC 7230, will be considered a malformed HTTP header and the BIG-IP system will reset the connection.”
the work around mentioned is to user trasparent http profile, which is:
“The Transparent Proxy Mode enables the BIG-IP system to forward invalid HTTP traffic to a specified server, instead of dropping the connection. By configuring an HTTP profile to forward invalid HTTP traffic, you can manage various atypical service provider scenarios, such as HTTP traffic from non-browser clients that function as web browsers.”
When http profile is changed to http transparent - everything works OK. (it looks that header which was suspicious has the same value on another environment on different device - and on that device everything is working fine).
How to check what header is malformed ? Is there any way to debug it ?
what great news, that it is working now. I think you can extract the headers and value pairs and check them by yourself and compare header names and values with RFC.
For example, the following HTTP request from the client causes the connection to be reset:
POST /web/page HTTP/1.1
Accept: */* aaabbbccc
Cache-Control: no-cache
Content-Length: 438
**Note:**The aaabbbccc header is malformed because it does not conform to the name: value syntax.
Using another example, the following HTTP request from the client also causes the connection to be reset:
Note: If there is a white space between the field name (aaabbbccc) and colon (:), then the request fails and the system considers it to be malformed. Full details about HTTP header restrictions are described in IETF RFC 7230: Hypertext Transfer Protocol (HTTP/1.1): Message Syntax and Routing.This link takes you to a resource outside of AskF5, and it is possible that the document may be removed without our knowledge.
Unfortunately, it is not mentioned in any of F5 articles how to check for the malformed header and know the header specifically, so you can check it by yourself by getting all of the header names and values.
