Best way to rewrite no redirect
All,
I’ve got an application that needs to re-write the url…not redirect. There is data being posted…so a redirect would lose the data.
So…
if { [HTTP::uri] contains “/specificfile.asp/” } {
? - but not a redirect…
Any suggestions?
Thanks,
Jim
maco0720
Hi Jim,
You can use HTTP::uri (Click here) or HTTP::path (Click here) to rewrite the URI or path.
You can check the HTTP::path wiki page for a description of the difference between the two commands.
Aaron
Aaron,
Thanks for the answer…unfortunately…I didn’t explain myself well. So here’s a better description.
I need to rewrite the entire url…based on the specific file in the URI.
So:
I need to change the url to one value as opposed to
if { [HTTP::uri] contains “/differentfile.asp/” } {
changes to a different url.
if
Fairway.com | Fairway Independent Mortgage Corp, NMLS ID 2289 send to http://www.away.com/whatever.asp
elseif
Fairway.com | Fairway Independent Mortgage Corp, NMLS ID 2289 sent to http://www.here.com/another.asp
So I’ve got to rewrite the incoming url to two totally different urls based on the file requested…but cannot redirect.
Thanks again,
Jim
So am I asking a question that has been covered a lot and I should be searching better for the answer (can’t seem to find anything that matches)…or is this not possible in everyone’s opinion.
Thanks,
Jim
maco0720
Hi Jim,
I just missed your reply last week. If you want to check the host value, you can use HTTP::host (Click here). To rewrite the Host header value, you can use ‘HTTP::header replace Host “newhost.example.com”’ (Click here). To get/set the URI, you can use HTTP::uri (Click here).
So to rewrite the host and URI without the client seeing the change, you can use an iRule like this:
    log local0. "[IP::client_addr]:[TCP::client_port]: New request to [HTTP::host][HTTP::uri]"
     Check host/uri (set to lowercase)
    switch "[string tolower [HTTP::host][HTTP::uri]]" {
       "www.home.com/specificfile.asp" {
           Rewrite host/URI
          HTTP::header replace Host "www.here.com"
          HTTP::uri "/whatever.asp"
          log local0. "[IP::client_addr]:[TCP::client_port]: Rewrite host/uri (1)"
       "www.home.com/differentfile.asp" {
           Rewrite host/URI
          HTTP::uri "/another.asp"
          log local0. "[IP::client_addr]:[TCP::client_port]: Rewrite host/uri (2)"
 Aaron
Hoolio…That helped alot…thanks. I’m still working on it…but will post the end result when the testing is done.
Thanks again!!!
Jim
