LTM Virtual edition v13. I have added a new VLAN (24) to work with on my LTM VE. It is working fine with VLAN 25 already.
Picked up an interface and added to the new VLAN and self IP mask /24 Then I copied a VIP working on another LTM VE on VLAN 24 to this LTM VE, same node, pool but picked up a different address for the VIP. VIP is up and is pingable, SNAT is pingable as well.
When i hit the VIP from my browser I got a connection reset message. A capture on the LTM shows like the node (server behind the f5) sends a RST to the SNAT.
If i remove the SNAT pool and use Automap the website loads properly. (tried configuring several VIPs and SNAT pools and same result)
I don’t now the reason of this behavior. SNAT pool is reachable from the server.
My goal is to have VIPs running fin on this new vlan 24.
Any help you can provide would be very appreciated.
Regards!
