Automap vs SNAT Pool on a Forwarding VS
Hello
I have set up a forwarding VS on the LTM, with the following configuration ltm virtual VLAN100-Forwarding { destination 0.0.0.0:any ip-forward mask any profiles { fastL4_stateless { } } snat automap translate-address disabled translate-port disabled vlans { LAN-VLAN100 } vlans-enabled
The issue I am having is when I associated a SNAT pool to this VS the servers that sit on this VLAN are no longer able to access the Internet, however automap works just fine. ltm snatpool my_SNAT-pool { members { 100.1.1.1 100.1.1.2 } My goal is to prevent port exhaustion; I have looked at using an iRule to attach to the VS like the one below or adding another self IP to the egress VLAN but the SNAT pool just seemed like a more cleaner approach when CLIENT_ACCEPTED { if { [IP::addr [IP::remote_addr] equals 172.26.100.0/255.255.255.0] } {
snatpool my_SNAT-pool } }
Any thoughts or idea why this would not work? I have read the solution articles about attaching to a SNAT pool directly to a VS and don’t think I am missing anything obvious. Thanks
What is the self IP address that is used for outgoing traffic when SNAT automap is configured on the virtual server? It could be a routing issue where your SNAT pool addresses aren’t being properly routed on your network. That’s just one of the things it could be, but maybe the most likely.
Your configuration looks fine.
Cory
Thanks for your response
The self-ip on the egress VLAN just uses a different last octet than the two indicated in the SNAT_pool,
I have verified the routing and from what I can see all are correct.
That is why I guess I am at a loss the config is not a complex one, but just looking to get another set of eyes or opinions on what it could be.
Thanks again
Another option could be access control on the network preventing the SNAT pool addresses from communicating out. If you do a tcpdump on your LTM, do you see any packets leaving sourced from the SNAT pool addresses?
tcpdump -nni 0.0 host 100.1.1.1 or 100.1.1.2
Again Cory thank you for your response
Ok I have completed some additional testing after gaining access to the server, if I use a SNAT pool with one IP (either of the two IP’s mentioned) it works as expected, however if I add an additional IP to the pool I am no longer able to access the Internet from my browser.
This would verify routing and access control..
Any thoughts on why this would not work?
Nothing immediately comes to mind as a potential problem. Do you see any errors/warnings in /var/log/ltm that may indicate a problem?
If not, try the tcpdump matching either of your SNAT pool IP addresses to see if the LTM is sending the traffic out as expected.
