Hello, I have a question about the new TMOS 13.1 running ASM standalone, since it is possible to perform basic load balance actions, how it handles the persistence when you load balance traffic? Because it is not possible to create Peresistence Profiles. I have seen that probably is possible using Local Traffic Policies but I am not sure.
Hi Juan,
As far as I know you cannot use load balancing when you have ASM standalone. Have you tried to create a pool with more that one member? You should get an error when you try. That’s probably why you can’t create persistence profiles either.
Hi Daniel,
Now it is possible to have basic load balancing features with ASM standalone running the 13.1 TMOS version. That is why I was asking if it has that feature it should have a way to persist sessions.
Hi guys,
Note one important thing; On above picture LTM is licensed. Even though it is not provisioned it is licensed so You can use persistence under ASM. Otherwise persistence profiles are not available at all.
