Suppose I have a BIG-IP device licensed for both LTM and ASM, but under System > Resource Provisioning, only the ASM module is enabled and set to Nominal.
Would the system still perform load balancing across multiple pool members in this case, or do I need to enable the LTM module to support that functionality? Which functionalities will be disabled ?
LTM functionality is not disabled by setting LTM provisioning to None. It just reduces the memory allocated to LTM-specific processes, but the core traffic management and load balancing features remain available as long as the license includes LTM.
Refer: K17173140: Setting LTM Provision NONE does not disable LTM functionality
As I understand, the LTM functionality is there even you have not provisioned the module. It is enough that the license is activated to have full LTM functionality.
The difference between licensed and provisioned is the reservation of memory for LTM.
You are right.
I just tried it and indeed I was able to use load balancing methods that are available only with LTM module.
Had never used LTM license without provision it so far.
Nice to learn new things.
Thanx @Juergen_Mang
