In 13.1.0.7 (I am not sure if it was the same in 13.1.4 but for sure not like that in 12.1.x) when security policy is applied via Security tab of VS configuration pop up allowing to disable or change policy is gone. Instead entry like that is presented:
Application Security PolicyManual Configuration (Advanced)
Why so? Is that some kind of weird improvement? With this change management becomes quite complicated:
- There is no way to figure out which policy is attached to VS (except checking Resources > Policies section of VS)
- There is no easy way to change or disable security policy (again Resources > Policies and detach Local traffic Policy pointing to security policy)
What is reason for this change, I can’t see any benefits.
Piotr
