Good morning all ,
Well i have to URL that are driving me crazy and i cannot figure out the best way to allow :
first one :
/email/id_user/user@outlook.com
==> trigger violation of file type
/email/id_user/user2@outlook.edu.us
==> trigger violation of file type i’m thinking about using regex but i don’t know how or where ( with Irules or in "allowed url " )
Second one :
image/avatar/pic01234521.jpg'/
==> trigger illegal metacharac so how can i allow the ’ but only in this path.
I’m looking for the most optimal , secure way to do this work .
And I know this should be simple but I just cant get it working?? Any help will be met with massive amounts respect.
Hi Amine,
If you want to get something like
through;
In “Allowed URLs”, you can create one like
image/avatar/*
Change it from “Explicit” to “Wildcard”
Click the “Meta Characters” tab that pops up next to “Attack Signatures”
Then add the
'(0x27)
from the list
That will allow any URI starting with
image/avatar/
, even if it contains a
metacharacter.
As to your first question, you could add each of those top level domains to the Allowed File Types. Each violation in the ASM logs should also allow you to learn them individually. If that’s impractical for you, you could also write an iRule. It could say something like, IF the URI starts with “/email/id_user/”, AND triggers a File Type Violation, it should be UNBLOCKED, but any other violations should remain BLOCKED.
it’s impossible to do it with file type, cauz i ll need to add a lot of extention .ma . fr .com .edu … a lot .. So i love u’re second suggestion ! but can you help more , i’ve no idea to make it work with Irule !
and also i want to thank you for ur help !
i wonder if i put this reg as allowed url \/([a-zA-Z0-9_\-.]+)@([a-zA-Z0-9_\-.]+).([a-zA-Z]{2,5})(\/.)?$
should it work ?
any further suggestion please ?
You can allow that regular expression in Application Security > Parameters > Parameters List. Create a new Explicit parameter, select “URL” for Parameter Level and enter your path. You can then enable the regular expression in the DataType tab. “enable” the check box and add your expression.
Here’s a good intro to how iRules works, but I think the following should unblock any request that starts with “/email/id_user/” and also triggers a filetype violation.
if { ([HTTP::uri] starts_with "/email/id_user/") and ([ASM::violation names] equals [VIOLATION_OBJ_TYPE]) } {
[ASM::unblock]
I hope this helps!
