Este anuncio ha sido actualizado para incluir una traducción al español. Puede encontrar las instrucciones en español al final de la publicación.
The iRules from Las Vegas and Berlin showcased incredible expertise. For this third iRules Contest, we’re shifting focus to encouragement and education for the theme:
“Write Your First iRule” Community Contest.
We’re challenging DevCentral community members attending AppWorld LATAM 2026 to design and build an iRule in a welcoming environment. Whether you are a first time iRules writer, or finding your footing, we can’t wait to see what you create.
(And don’t worry, it doesn’t have to be your literal first iRule ever. It’s the spirit of trying something new that counts.)
The Challenge
Plan out and write an iRule that tackles a use-case for BIG-IP’s capabilities. You can:
- Create a new iRule
- Reimagine existing codeshare iRules from DevCentral
- Adapt a 20-lines-or-less iRule from the GitHub iRules Toolbox
We value your fresh perspective and newer eyes. As this is a learning opportunity, we also encourage having fun with it.
Prizes
The submissions will be judged for category awards. All participants receive an exclusive contest t-shirt.
| Place | Prize |
| Category Awards | $200/each |
| Technical Excellence Award | $500 |
| Participation | t-shirt |
What Makes for a Winning Entry?
The 100-point scale judging criteria for submissions is defined below across four categories:
Technical Excellence (25 points)
Is it well-built and production ready? Consider
- Works correctly
- Performance-conscious (efficient, minimal resource impact)
- Follows security best practices
- Clean, readable code
User Impact (25 points)
Would you and other users actually use this? Consider:
- Solves a real operational problem or technical need need
- Practical applicability and potential adoption
- Clear business value
- Thorough documentation
Innovation & Creativity (25 points)
Does this solution show original thinking? Consider:
- Fresh perspective on common challenges
- Unique approach solving a modern problem
- Does it inspire collaboration and progress?
Theme & Alignment (25 points)
Does this iRule reflect your learnings from AppWorld LATAM 2026 and community resources? Consider:
- Applying the knowledge and skills you’ve learned
- Approachable to other new iRules writers
- Shows your effort to try something new to you
Important Dates
Contest Opens: June 8th, 2026 at 12:00am Pacific Time
Submission Deadline: July 31st, 2026 at 11:59pm Pacific Time
Winners Announced: August 14th, 2026
How to Enter
- The contest is open to all F5 partners, customers, and DevCentral members registered for and in attendance at the contest at AppWorld LATAM 2026, except as described in the Official Rules. Please see the Official Rules for complete terms, including conditions for participation and eligibility.
- Sign up for DevCentral and join the Community Contests group. Find Hannah or Buu at the Community area if you need any assistance.
- Build and submit before 11:59pm Pacific Time JULY 31, 2026. Edit your draft entry as much as you like, but once you submit, that’s what we’ll review. Here an example entry pinned at the top of the Contest Entries page you should follow. Make sure to add these tags to your entry: “appworld 2026”, “latam”, and “irules” as shown on that example. IMPORTANT - You need to join the Contests group to submit your entry.
New to iRules?
Perfect! We welcome participants at all skill levels. If you’re just getting started, check out our Getting Started with iRules: Basic Concepts guide. This contest is a great opportunity to learn by doing. Feel free to bring your favorite colleagues and AI buddies to help craft your entry.
Final Thoughts
Post any and all of your contest-related questions in comments below.
The iRules Contest has a rich history of surfacing creative solutions from the community. Approaching problems differently inspires some of the best ideas we’ve seen. We’re looking forward to seeing and celebrating what you build.
Learn it. Build it. Share it.
See you at AppWorld LATAM 2026!
AppWorld LATAM 2026 - Concurso “Escribe tu Primer iRule”
¡Hola querida comunidad! El Concurso de iRules está de regreso, con un nuevo estilo.
Los iRules de Las Vegas y Berlín demostraron una experiencia increíble. Para este tercer Concurso de iRules, cambiaremos el enfoque hacia el estímulo y la educación con el tema:
Concurso Comunitario “Escribe tu Primer iRule”.
Estamos desafiando a los miembros de la comunidad DevCentral que asistan a AppWorld LATAM 2026 a diseñar y construir un iRule en un entorno acogedor. Ya sea que estés escribiendo un iRule por primera vez, o apenas estés encontrando tu ritmo, no podemos esperar a ver lo que crees.
(Y no te preocupes, no tiene que ser literalmente tu primer iRule. Lo que cuenta es el espíritu de intentar algo nuevo.)
El Desafío
Planea y escribe un iRule que aborde un caso de uso de las capacidades de BIG-IP. Puedes:
- Crear un nuevo iRule
- Reimaginar los iRules existentes del codeshare de DevCentral
- Adaptar un iRule de 20 líneas o menos del GitHub iRules Toolbox
Valoramos tu perspectiva fresca y tu mirada renovada. Como es una oportunidad de aprendizaje, también te animamos a divertirte con ello.
Premios
Las presentaciones serán evaluadas para los premios por categoría. Todos los participantes reciben una camiseta exclusiva del concurso.
| Puesto | Premio |
| Premios por Categoría | $200/cada uno |
| Premio a la Excelencia Técnica | $500 |
| Participación | camiseta |
¿Qué Hace a una Entrada Ganadora?
Los criterios de evaluación de 100 puntos para las presentaciones se definen a continuación en cuatro categorías:
Excelencia Técnica (25 puntos)
¿Está bien construido y listo para producción? Considera:
- Funciona correctamente
- Consciente del rendimiento (eficiente, impacto mínimo en recursos)
- Sigue las mejores prácticas de seguridad
- Código limpio y legible
Impacto en el Usuario (25 puntos)
¿Tú y otros usuarios realmente lo usarían? Considera:
- Resuelve un problema operativo real o una necesidad técnica
- Aplicabilidad práctica y potencial de adopción
- Valor de negocio claro
- Documentación exhaustiva
Innovación y Creatividad (25 puntos)
¿Esta solución muestra un pensamiento original? Considera:
- Perspectiva fresca sobre desafíos comunes
- Enfoque único para resolver un problema moderno
- ¿Inspira colaboración y progreso?
Tema y Alineación (25 puntos)
¿Este iRule refleja tu aprendizaje de AppWorld LATAM 2026 y de los recursos de la comunidad? Considera:
- Aplicar el conocimiento y las habilidades que has aprendido
- Accesible para otros nuevos escritores de iRules
- Demuestra tu esfuerzo por intentar algo nuevo para ti
Fechas Importantes
Apertura del Concurso: 8 de junio de 2026 a las 12:00 a.m. Hora del Pacífico
Fecha Límite de Presentación: 31 de julio de 2026 a las 11:59 p.m. Hora del Pacífico
Anuncio de Ganadores: 14 de agosto de 2026
Cómo Participar
- El concurso está abierto a todos los socios y clientes de F5, y miembros de DevCentral que estén registrados y asistan al concurso en AppWorld LATAM 2026, excepto como se describe en las Reglas Oficiales. Por favor consulta las Reglas Oficiales para los términos completos, incluidas las condiciones de participación y elegibilidad.
- Regístrate en DevCentral y únete al grupo Community Contests. Busca a Hannah o Buu en el área de la Comunidad si necesitas ayuda.
- Construye y envía antes de las 11:59 p.m. Hora del Pacífico del 31 de JULIO de 2026. Edita tu borrador tanto como quieras, pero una vez que lo envíes, eso es lo que revisaremos. Aquí tienes un ejemplo de entrada anclado al inicio de la página de Contest Entries que deberías seguir. Asegúrate de agregar estas etiquetas a tu entrada: “appworld 2026”, “latam” e “irules” como se muestra en ese ejemplo. IMPORTANTE - Necesitas unirte al grupo Contests para enviar tu entrada.
¿Nuevo en iRules?
¡Perfecto! Damos la bienvenida a participantes de todos los niveles de habilidad. Si recién estás comenzando, consulta nuestra guía Getting Started with iRules: Basic Concepts. Este concurso es una gran oportunidad para aprender haciendo. Siéntete libre de traer a tus colegas favoritos y a tus compañeros de IA para ayudarte a crear tu entrada.
Reflexiones Finales
Publica todas tus preguntas relacionadas con el concurso en los comentarios a continuación.
El Concurso de iRules tiene una rica historia de hacer emerger soluciones creativas desde la comunidad. Abordar los problemas de manera diferente inspira algunas de las mejores ideas que hemos visto. Esperamos con ansias ver y celebrar lo que construyas.
