Problem this snippet solves:
Updated version to support Webdav with windows explorer after Nicolas’s comment.
APM is a great authentication service but it does it only with forms.
The default behavior is to redirect user to /my.policy to process VPE. this redirect is only supported for GET method.
Sharepoint provide 3 different access types:
- browsing web site with a browser
- Editing documents with Office
- browser folder with webdav client (or editing documents with libreoffice through webdav protocol)
This irule display best authentication method for each of these access types:
- browsers authenticate with default authentication method (form based authentication)
- Microsoft office authenticate with Form based authentication (with support of MS-OFBA protocol)
- Libreoffice and webdav clients authenticate with 401 basic authentication
Form based authentication (browser and Microsoft office) is compatible (validated for one customer) with SAML authentication
Editing documents is managed with a persistent cookie expiring after 5 minutes. to be shared between IE and Office, it requires :
- cookie is persistent (expiration date instead of deleted at the end of session)
- web site defined as “trusted sites” in IE.
How to use this snippet:
install this irule and enable it on the VS.
Code :
when RULE_INIT {
array set static::MSOFBA {
ReqHeader "X-FORMS_BASED_AUTH_REQUIRED"
ReqVal "/sp-ofba-form"
ReturnHeader "X-FORMS_BASED_AUTH_RETURN_URL"
ReturnVal "/sp-ofba-completed"
SizeHeader "X-FORMS_BASED_AUTH_DIALOG_SIZE"
SizeVal "800x600"
set static::ckname "MRHSession_SP"
set static::Basic_Realm_Text "SharePoint Authentication"
set apmsessionid [HTTP::cookie value MRHSession]
set persist_cookie [HTTP::cookie value $static::ckname]
set clientless_mode 0
set form_mode 0
# Identify User-Agents type
if {[HTTP::header exists "X-FORMS_BASED_AUTH_ACCEPTED"] && (([HTTP::header "X-FORMS_BASED_AUTH_ACCEPTED"] equals "t") || ([HTTP::header "X-FORMS_BASED_AUTH_ACCEPTED"] equals "f"))} {
set clientless_mode 0; set form_mode 1
switch -glob [string tolower [HTTP::header "User-Agent"]] {
"*microsoft-webdav-miniredir*" { set clientless_mode 1 }
"*microsoft data access internet publishing provider*" -
"*office protocol discovery*" -
"*microsoft office*" -
"*non-browser*" -
"msoffice 12*" { set form_mode 1 }
"*mozilla/4.0 (compatible; ms frontpage*" {
if { [ string range [getfield [string tolower [HTTP::header "User-Agent"]] "MS FrontPage " 2] 0 1] > 12 } {
set form_mode 1
"*mozilla*" -
"*opera*" { set clientless_mode 0 }
default { set clientless_mode 1
if { $clientless_mode || $form_mode } {
if { [HTTP::cookie exists "MRHSession"] } {set apmstatus [ACCESS::session exists -state_allow $apmsessionid]} else {set apmstatus 0}
if { !($apmstatus) && [HTTP::cookie exists $static::ckname] } {set apmpersiststatus [ACCESS::session exists -state_allow $persist_cookie]} else {set apmpersiststatus 0}
if { ($apmpersiststatus) && !($apmstatus) } {
# Add MRHSession cookie for non browser user-agent first request and persistent cookie present
if { [catch {HTTP::cookie insert name "MRHSession" value $persist_cookie} ] } {log local0. "[IP::client_addr]:[TCP::client_port] : TCL error on HTTP cookie insert MRHSession : URL : [HTTP::host][HTTP::path] - Headers : [HTTP::request]"} else {return}
} else { return }
if { $clientless_mode && !($apmstatus)} {
if { !([HTTP::header Authorization] == "") } {
set clientless(insert_mode) 1
set clientless(username) [ string tolower [HTTP::username] ]
set clientless(password) [HTTP::password]
binary scan [md5 "$clientless(password)"] H* clientless(hash)
set user_key "$clientless(username).$clientless(hash)"
set clientless(cookie_list) [ ACCESS::user getsid $user_key ]
if { [ llength $clientless(cookie_list) ] != 0 } {
set clientless(cookie) [ ACCESS::user getkey [ lindex $clientless(cookie_list) 0 ] ]
if { $clientless(cookie) != "" } {
HTTP::cookie insert name MRHSession value $clientless(cookie)
set clientless(insert_mode) 0
if { $clientless(insert_mode) } {
HTTP::header insert "clientless-mode" 1
HTTP::header insert "username" $clientless(username)
HTTP::header insert "password" $clientless(password)
unset clientless
HTTP::respond 401 WWW-Authenticate "Basic realm=\"$static::Basic_Realm_Text\"" Set-Cookie "MRHSession=deleted; expires=Thu, 01-Jan-1970 00:00:01 GMT; path=/" Connection close
return
} elseif {$form_mode && !($apmstatus) && !([HTTP::path] equals $static::MSOFBA(ReqVal))}{
HTTP::respond 403 -version "1.1" noserver \
$static::MSOFBA(ReqHeader) "https://[HTTP::host]$static::MSOFBA(ReqVal)" \
$static::MSOFBA(ReturnHeader) "https://[HTTP::host]$static::MSOFBA(ReturnVal)" \
$static::MSOFBA(SizeHeader) $static::MSOFBA(SizeVal) \
"Connection" "Close"
return
when HTTP_RESPONSE {
# Insert persistent cookie for html content type and private session
if { [HTTP::header "Content-Type" ] contains "text/html" } {
HTTP::cookie remove $static::ckname
HTTP::cookie insert name $static::ckname value $apmsessionid path "/"
HTTP::cookie expires $static::ckname 120 relative
HTTP::cookie secure $static::ckname enable
# Insert session cookie if session was recovered from persistent cookie
if { ([info exists "apmpersiststatus"]) && ($apmpersiststatus) } {
HTTP::cookie insert name MRHSession value $persist_cookie path "/"
HTTP::cookie secure MRHSession enable
when ACCESS_SESSION_STARTED {
if {([info exists "clientless_mode"])} {
ACCESS::session data set session.clientless $clientless_mode
if { [ info exists user_key ] } {
ACCESS::session data set "session.user.uuid" $user_key
when ACCESS_POLICY_COMPLETED {
if { ([info exists "clientless_mode"]) && ($clientless_mode) && ([ACCESS::policy result] equals "deny") } {
ACCESS::respond 401 noserver WWW-Authenticate "Basic realm=$static::Basic_Realm_Text" Connection close
ACCESS::session remove
when ACCESS_ACL_ALLOWED {
switch -glob [string tolower [HTTP::path]] {
"/sp-ofba-form" {
ACCESS::respond 302 noserver Location "https://[HTTP::host]$static::MSOFBA(ReturnVal)"
"/sp-ofba-completed" {
ACCESS::respond 200 content {
<title>Authenticated</title>
<b>Good Work, you are Authenticated</b>
} noserver
"*/signout.aspx" {
# Disconnect session and redirect to APM logout Page
ACCESS::respond 302 noserver Location "/vdesk/hangup.php3"
return
"/_layouts/accessdenied.aspx" {
# Disconnect session and redirect to APM Logon Page
if {[string tolower [URI::query [HTTP::uri] loginasanotheruser]] equals "true" } {
ACCESS::respond 302 noserver Location "/"
return
default {
# No Actions
Tested this on version:
11.5
