I have configured an access profile with AD authentication then OTP using email. But, the email was not received !! I tried both exchange and yahoo mails but with no luck. for example i tried to send email to yahoo mail using this. Any help why it doesn’t work ?!
Have you tried a curl test from APM directly?
Do you have authentication to the smtp provider set up? It is not set in the screen shot. I think smtp.bizmail.yahoo.com requires authentication, otherwise it would be banned as an open relay.. If yes, then try to troubleshoote connection & parameters with curl from BIG-IP command line as kunjan suggests.
how to test it using curl ?!
This might help: Yahoo mail login
