Hi All,
I just need to get someone to help clarify the difference between the fast_l4 profile and the apm-forwarding-fastl4 profile. I’ve been having issues on my 2200 at work with outbound traffic being blocked by the system even though I had the fast_l4 configured with loose connection setting enabled.
I started playing around with settings and used the apm l4 profile and outbound traffic went through fine. Also noticed that the LTM is now caching connections because when i remove the VS outbound traffic is still being allowed and processed by the LTM for an unspecified amount of time. I cannot find any documentation on this.
