Hello I’m trying to create a connection from a Google Nexus 10 to APM with Certificate Authentication. I’ve tried to import the P12 user certificate I’m already using with other iOS devices. I have been able to install the certificate in the Android System. But I’m afraid Edge Client need to import it in its own container. When I try to use the Edge Client “Import Certificate” functionality I choose “Download” as the Nexus 10 has no SD Card Slot. The certificate is actually downloaded but I always get the same error “Please enter the correct password”. I’m sure I’m typing the right password. I’ve even changed the password with no success. Any help? Regards
I’ve tried with a Samsung Galaxy S4 and it happens the same. I can’t import the certificate using URL Download. Fortunately, the S4 does support external SD cards. And the certificate can be imported from the SD card.
I opened a supposed case and F5 has been able to reproduce the issue. They will deliver a fix
Was this issue fixed? I am having a similar issue.
