Did anyone have this error before?
Basically we are using authentication and authorization through TACACS.
One of remote users with the auditor role ran the command “show running-config” to grep all configuration on the LTM. Then the user encountered the following error.
Error Message
Unexpected Error: Can’t chmod key management directory: “/var/tmp/key_mgmt”, error: [1] Operation not permitted
Environment
BIG-IP: 11.5.4 HF2
Authentication/Authorization: TACACS
I did some googling and found below release note. Then I tried the workaround but it didn’t fix the problem. BIG-IP 11.5.4 Release Note: BIG-IP 11.5.4 LTM and TMOS Release Notes Go to Known bug (568566)
I wonder if there is any better solution or only solution is to upgrade BIG-IP?
Thank you
