my boss has asked me if the following is possible to have a single virtual server (with a SSL cert) for multiple web based applications. For example he would like to use our one SSL cert for WebSphere, PeopleSoft, OWA, and a few other web based apps. At the moment some of these have their own Verisign SSL certs, and some are using self signed certs. Now not being a BigIP guru I am not sure if this is possible, but he thinks it is, or was told by someone it was.
Although I can see at first glance this may be possible providing a unique URI can be allocated for each web based appplication
eg. /exchange for OWA
/wps/portal for WebSphere
I am concerned that these various apps may/will have conflicting persistence profiles or other settings that are applied at the virtual server level and not defineable within the iRule. For example, you can specify the pool as config option (default pool) or in the iRule. Can the other settings like
- default persistance Profile
- HTTP Profile
- VLAN List
be defined within the iRlule?
In the end my boss wants to reduce the costs of all the Verisgn SSL certs we use, and at $1600 each I can see some sense in this. I realise there are cheaper SSL certs like those from GoDaddy, but I don’t know much about the company and how well they are supported by browswers.
Anyway I would appreciate any comments on whether the BigIP can do what Ive been asked to make it do. Any comments on GoDaddy SSL certs would also be welcome, assuming it doesn’t violate any forum rules.
tia
Craig
