Since v15.1 (in draft), F5® BIG-IP® Advanced WAF™ can import Declarative WAF policy in JSON format.
The F5® BIG-IP® Advanced Web Application Firewall (Advanced WAF) security policies can be deployed using the declarative JSON format, facilitating easy integration into a CI/CD pipeline. The declarative policies are extracted from a source control system, for example Git, and imported into the BIG-IP.
Using the provided declarative policy templates, you can modify the necessary parameters, save the JSON file, and import the updated security policy into your BIG-IP devices. The declarative policy copies the content of the template and adds the adjustments and modifications on to it. The templates therefore allow you to concentrate only on the specific settings that need to be adapted for the specific application that the policy protects.
This Declarative WAF JSON policy is similar to NGINX App Protect policy. You can find more information on the Declarative Policy here :
- NAP : https://docs.nginx.com/nginx-app-protect/policy/
- Adv. WAF : https://techdocs.f5.com/en-us/bigip-15-1-0/big-ip-declarative-security-policy.html
Audience
This guide is written for IT professionals who need to automate their WAF policy and are familiar with Advanced WAF configuration. These IT professionals can fill a variety of roles:
- SecOps deploying and maintaining WAF policy in Advanced WAF
- DevOps deploying applications in modern environment and willing to integrate Advanced WAF in their CI/CD pipeline
- F5 partners who sell technology or create implementation documentation
This article covers how to PUSH/PULL a declarative WAF policy in Advanced WAF:
- With Postman
- With AS3
Table of contents
- Upload Policy in BIG-IP
- Check the import
- Apply the policy
- OpenAPI Spec File import
- AS3 declaration
- CI/CD integration
- Find the Policy-ID
- Update an existing policy
- Video demonstration
First of all, you need a JSON WAF policy, as below :
"policy": {
"name": "policy-api-arcadia",
"description": "Arcadia API",
"template": {
"name": "POLICY_TEMPLATE_API_SECURITY"
"enforcementMode": "blocking",
"server-technologies": [
"serverTechnologyName": "MySQL"
"serverTechnologyName": "Unix/Linux"
"serverTechnologyName": "MongoDB"
"signature-settings": {
"signatureStaging": false
"policy-builder": {
"learnOnlyFromNonBotTraffic": false
1. Upload Policy in BIG-IP
There are 2 options to upload a JSON file into the BIG-IP:
1.1 Either you PUSH the file into the BIG-IP and you IMPORT IT
OR
1.2 the BIG-IP PULL the file from a repository (and the IMPORT is included) ← BEST option
1.1 PUSH JSON file into the BIG-IP
The call is below. As you can notice, it requires a ‘Content-Range’ header. And the value is 0-(filesize-1)/filesize. In the example below, the file size is 662 bytes. This is not easy to integrate in a CICD pipeline, so we created the PULL method instead of the PUSH (in v16.0)
curl --location --request POST 'https://10.1.1.12/mgmt/tm/asm/file-transfer/uploads/policy-api.json' \
--header 'Content-Range: 0-661/662' \
--header 'Authorization: Basic YWRtaW46YWRtaW4=' \
--header 'Content-Type: application/json' \
--data-binary '@/C:/Users/user/Desktop/policy-api.json'
At this stage, the policy is still a file in the BIG-IP file system. We need to import it into Adv. WAF. To do so, the next call is required.
This call import the file “policy-api.json” uploaded previously. An CREATE the policy /Common/policy-api-arcadia
curl --location --request POST 'https://10.1.1.12/mgmt/tm/asm/tasks/import-policy/' \
--header 'Content-Type: application/javascript' \
--data-raw '{
"filename":"policy-api.json",
"policy":
"fullPath":"/Common/policy-api-arcadia"
1.2 PULL JSON file from a repository
Here, the JSON file is hosted somewhere (in Gitlab or Github …). And the BIG-IP will pull it.
The call is below. As you can notice, the call refers to the remote repo and the body is a JSON payload. Just change the link value with your JSON policy URL.
With one call, the policy is PULLED and IMPORTED.
--data-raw '{
"fileReference": {
"link": "http://10.1.20.4/root/as3-waf/-/raw/master/policy-api.json"
A second version of this call exists, and refer to the fullPath of the policy. This will allow you to update the policy, from a second version of the JSON file, easily. One call for the creation and the update.
As you can notice below, we add the “policy”:“fullPath” directive. The value of the “fullPath” is the partition and the name of the policy set in the JSON policy file.
This method is VERY USEFUL for CI/CD integrations.
--data-raw '{
"fileReference": {
"policy":
2. Check the IMPORT
Check if the IMPORT worked. To do so, run the next call.
curl --location --request GET 'https://10.1.1.12/mgmt/tm/asm/tasks/import-policy/' \
You should see a 200 OK, with the content below (truncated in this example).
Please notice the “status”:“COMPLETED”.
"kind": "tm:asm:tasks:import-policy:import-policy-taskcollectionstate",
"selfLink": "https://localhost/mgmt/tm/asm/tasks/import-policy?ver=16.0.0",
"totalItems": 11,
"items": [
"isBase64": false,
"executionStartTime": "2020-07-21T15:50:22Z",
"status": "COMPLETED",
"lastUpdateMicros": 1.595346627e+15,
"getPolicyAttributesOnly": false,
From now, your policy is imported and created in the BIG-IP. You can assign it to a VS as usual (Imperative Call or AS3 Call). But in the next session, I will show you how to create a Service with AS3 including the WAF policy.
3. APPLY the policy
As you may know, a WAF policy needs to be applied after each change. This is the call.
curl --location --request POST 'https://10.1.1.12/mgmt/tm/asm/tasks/apply-policy/' \
--data-raw '{"policy":{"fullPath":"/Common/policy-api-arcadia"}}'
4. OpenAPI spec file IMPORT
As you know, Adv. WAF supports OpenAPI spec (2.0 and 3.0). Now, with the declarative WAF, we can import the OAS file as well. The BEST solution, is to PULL the OAS file from a repo. And in most of the customer’ projects, it will be the case.
In the example below, the OAS file is hosted in SwaggerHub (Github for Swagger files). But the file could reside in a private Gitlab repo for instance.
- The URL of the project is : https://app.swaggerhub.com/apis/F5EMEASSA/Arcadia-OAS3/1.0.0-oas3
- The URL of the OAS file is : https://api.swaggerhub.com/apis/F5EMEASSA/Arcadia-OAS3/1.0.0-oas3
This swagger file (OpenAPI 3.0 Spec file) includes all the application URL and parameters. What’s more, it includes the documentation (for NGINX APIm Dev Portal).
Now, it is pretty easy to create a WAF JSON Policy with API Security template, referring to the OAS file.
Below, you can notice the new section “open-api-files” with the link reference to SwaggerHub. And the new template POLICY_TEMPLATE_API_SECURITY.
Now, when I upload / import and apply the policy, Adv. WAF will download the OAS file from SwaggerHub and create the policy based on API_Security template.
"policy": {
"template": {
"policy-builder": {
"open-api-files": [
"link": "https://api.swaggerhub.com/apis/F5EMEASSA/Arcadia-OAS3/1.0.0-oas3"
5. AS3 declaration
Now, it is time to learn how we can do all of these steps in one call with AS3 (3.18 minimum).
The documentation is here : https://clouddocs.f5.com/products/extensions/f5-appsvcs-extension/latest/declarations/application-security.html?highlight=waf_policy#virtual-service-referencing-an-external-security-policy
With this AS3 declaration, we:
- Import the WAF policy from a external repo
- Import the Swagger file (if the WAF policy refers to an OAS file) from an external repo
- Create the service
"class": "AS3",
"action": "deploy",
"persist": true,
"declaration": {
"class": "ADC",
"schemaVersion": "3.2.0",
"id": "Prod_API_AS3",
"API-Prod": {
"class": "Tenant",
"defaultRouteDomain": 0,
"API": {
"class": "Application",
"template": "generic",
"VS_API": {
"class": "Service_HTTPS",
"remark": "Accepts HTTPS/TLS connections on port 443",
"virtualAddresses": ["10.1.10.27"],
"redirect80": false,
"pool": "pool_NGINX_API_AS3",
"policyWAF": {
"use": "Arcadia_WAF_API_policy"
"securityLogProfiles": [{
"bigip": "/Common/Log all requests"
"profileTCP": {
"egress": "wan",
"ingress": { "use": "TCP_Profile" } },
"profileHTTP": { "use": "custom_http_profile" },
"serverTLS": { "bigip": "/Common/arcadia_client_ssl" }
"Arcadia_WAF_API_policy": {
"class": "WAF_Policy",
"url": "http://10.1.20.4/root/as3-waf-api/-/raw/master/policy-api.json",
"ignoreChanges": true
"pool_NGINX_API_AS3": {
"class": "Pool",
"monitors": ["http"],
"members": [{
"servicePort": 8080,
"serverAddresses": ["10.1.20.9"]
"custom_http_profile": {
"class": "HTTP_Profile",
"xForwardedFor": true
"TCP_Profile": {
"class": "TCP_Profile",
"idleTimeout": 60 }
6. CI/CID integration
As you can notice, it is very easy to create a service with a WAF policy pulled from an external repo. So, it is easy to integrate these calls (or the AS3 call) into a CI/CD pipeline.
Below, an Ansible playbook example. This playbook run the AS3 call above.
That’s it ![]()
- hosts: bigip
connection: local
gather_facts: false
vars:
my_admin: "admin"
my_password: "admin"
bigip: "10.1.1.12"
tasks:
- name: Deploy AS3 WebApp
uri:
url: "https://{{ bigip }}/mgmt/shared/appsvcs/declare"
method: POST
headers:
"Content-Type": "application/json"
"Authorization": "Basic YWRtaW46YWRtaW4="
body: "{{ lookup('file','as3.json') }}"
body_format: json
validate_certs: no
status_code: 200
7. FIND the Policy-ID
When the policy is created, a Policy-ID is assigned. By default, this ID doesn’t appear anywhere. Neither in the GUI, nor in the response after the creation.
You have to calculate it or ask for it. This ID is required for several actions in a CI/CD pipeline.
7.1 Calculate the Policy-ID
We created this python script to calculate the Policy-ID. It is an hash from the Policy name (including the partition). For the previous created policy named “/Common/policy-api-arcadia”, the policy ID is “Ar5wrwmFRroUYsMA6DuxlQ”
Paste this python code in a new waf-policy-id.py file, and run the command python waf-policy-id.py “/Common/policy-api-arcadia”
Outcome will be The Policy-ID for /Common/policy-api-arcadia is: Ar5wrwmFRroUYsMA6DuxlQ
#!/usr/bin/python
from hashlib import md5
import base64
import sys
pname = sys.argv[1]
print 'The Policy-ID for', sys.argv[1], 'is:', base64.b64encode(md5(pname.encode()).digest()).replace("=", "")
7.2 Retrieve the Policy-ID and fullPath with a REST API call
Make this call below, and you will see in the response, all the policy creations. Find yours and collect the PolicyReference directive. The Policy-ID is in the link value “link”: “https://localhost/mgmt/tm/asm/policies/**Ar5wrwmFRroUYsMA6DuxlQ**?ver=16.0.0”
You can see as well, at the end of the definition, the "fileReference" referring to the JSON file pulled by the BIG-IP.
And please notice the “fullPath”, required if you want to update your policy
--header 'Content-Range: 0-601/601' \
"isBase64": false,
"executionStartTime": "2020-07-22T11:23:42Z",
"lastUpdateMicros": 1.595417027e+15,
"kind": "tm:asm:tasks:import-policy:import-policy-taskstate",
"selfLink": "https://localhost/mgmt/tm/asm/tasks/import-policy/B45J0ySjSJ9y9fsPZ2JNvA?ver=16.0.0",
"filename": "",
"policyReference": {
"link": "https://localhost/mgmt/tm/asm/policies/Ar5wrwmFRroUYsMA6DuxlQ?ver=16.0.0",
"fullPath": "/Common/policy-api-arcadia"
"endTime": "2020-07-22T11:23:47Z",
"startTime": "2020-07-22T11:23:42Z",
"id": "B45J0ySjSJ9y9fsPZ2JNvA",
"retainInheritanceSettings": false,
"result": {
"message": "The operation was completed successfully. The security policy name is '/Common/policy-api-arcadia'. "
"fileReference": {
8 UPDATE an existing policy
It is pretty easy to update the WAF policy from a new JSON file version. To do so, collect from the previous call 7.2 Retrieve the Policy-ID and fullPath with a REST API call the “Policy” and “fullPath” directive. This is the path of the Policy in the BIG-IP.
Then run the call below, same as 1.2 PULL JSON file from a repository, but add the Policy and fullPath directives
Don’t forget to APPLY this new version of the policy 3. APPLY the policy
--data-raw '{
"fileReference": {
"policy":
TIP : this call, above, can be used in place of the FIRST call when we created the policy “1.2 PULL JSON file from a repository”. But be careful, the fullPath is the name set in the JSON policy file.
The 2 values need to match:
- “name”: “policy-api-arcadia” in the JSON Policy file pulled by the BIG-IP
- “policy”:“fullPath” in the POST call
9 Video demonstration
In order to help you to understand how it looks with the BIG-IP, I created this video covering 4 topics explained in this article :
- The JSON WAF policy
- Pull the policy from a remote repository
- Update the WAF policy with a new version of the declarative JSON file
- Deploy a full service with AS3 and Declarative WAF policy
At the end of this video, you will be able to adapt the REST Declarative API calls to your infrastructure, in order to deploy protected services with your CI/CD pipelines.
Direct link to the video on DevCentral YouTube channel : https://youtu.be/EDvVwlwEFRw
