Hi Jason,
here is the our rules, app team tested and they say still persisted and “persist none” didn’t work.
i opened case and support does not help us.
Switch_irule
log local0. “[IP::client_addr]:[TCP::client_port]: [HTTP::method] request to [HTTP::host][HTTP::uri]”
switch -glob [HTTP::uri] {
“/uat/JAVA*” {
pool Persist_Test_Pool_1
HTTP::uri [string map -nocase {“/uat/JAVA” “/JAVA”} [HTTP::uri]]
log local0. “[IP::client_addr]:[TCP::client_port]: matched [HTTP::uri]. Pool: [LB::server]”
"/uat/abc/*” {
pool Persist_Test_Pool_2
persist none
HTTP::uri [string map -nocase {"/uat/abc/“ “/test/“} [HTTP::uri]]
“default” {
log local0. “No match”
Jsessionid_rule
# Log details for the request
set log_prefix “[IP::client_addr]:[TCP::client_port]”
log local0. “$log_prefix: Request to [HTTP::uri] with cookie: [HTTP::cookie value JSESSIONID]”
# only header cookie control
if { [HTTP::header exists “Cookie”] } {
set jsess [findstr [string tolower [HTTP::header “Cookie”]] “jsessionid=” “11” “.” ]
if { $jsess != “” } {
persist uie $jsess 3600
log local0. “$log_prefix: Used persistence record from path: [persist lookup uie $jsess] $jsess”
when HTTP_RESPONSE {
if { [HTTP::header exists “Set-Cookie”] } {
set jsess [findstr [string tolower [HTTP::header “Set-Cookie”]] “jsessionid=” “11” “.” ]
persist add uie $jsess 3600
log local0. “$log_prefix: Added persistence record from cookie: [persist lookup uie $jsess] $jsess”
