ACA+CRLDP=iRules?
I need some info for using and F5 with CRL for client side cert checking. I’ve done this on a Juniper within the Trusted Client CA setup where I can use OCSP or use just CRL’s. I just need to add the http path and CRL download frequency. I’ve looked at the F5 support and devcentral but have found nothing that talks about this. The support CRL put as a file on the F5 and/or OCSP only. Can the F5 be setup the same as a Juniper or can I use a iRule for this. What I really want is to use the CRLDP method. Can this actually happen, and if so, how?
Thanks, smiley
You must have double posted.
I replied to your other post: http://devcentral.f5.com/Community/GroupDetails/tabid/1082223/asg/50/aft/1184822/showtab/groupforums/Default.aspx
