010713d0:3: Symmetric Unit Key decrypt failure - decrypt failure Rseries Tenant ..
Hello, I have previously uploaded the configuration with ucs to Rseries Tenant. When I want to upload the final version of ucs to enable the latest updates, it gives an error. Can anyone help me with this?
The command I used when installing:
load /sys ucs /var/local/ucs/ALP-30092024.ucs no-license no-platform-check
error I got
 load_config_files[23122]: “/usr/bin/tmsh -n -g -a load sys config partitions all base “ - failed. -- Loading schema version: 15.1.3.1
Loading schema version: 17.1.1.1.3
Unexpected Error: Loading configuration process failed.
I suggest using the journeys tool GitHub - f5devcentral/f5-journeys: F5 Journeys Migration Utility - migrate or upgrade BIG-IP into new F5 platforms as it mentions that for migration like RMA the master key should be copied to the new system.
Thank you for your reply, I will check immediately.
Hi @Ozzy   if my answer helped you please mark it as “solved”.
