The (hopefully) definitive guide to load balancing Lync Edge Servers with a Hardware Load Balancer
Having worked on a few large Lync deployments recently, I have realized that there is still a lot of confusion around properly architecting the network for load balancing Lync Edge Servers. Guida...
Published Jul 14, 2011
Version 1.0Ryan_Korock_46
Historic F5 Account
electroboard_13
Sep 25, 2013Hi, great artical even if it is old it is still relevent.
have a lync 2010 edge servers load balanced using the F5-LTM and have poor audio quality for external users. i have been stepping through the IAPP for lync to see if there is anything missing with no luck. your guide has been useful, however i am not sure what a DNAT is?
Can you confirm if using the Lync iAPP follows best practice or is there something i should be adjusting. i.e.load balancing method?
