Site Launch Frequently Asked Questions
Hey there, community. We are maintaining this FAQ as new issues come in that might be experienced by the community at large. This will be continually updated as we fix the discovered issues.
Login...
Published May 17, 2019
Version 1.0Chase_Abbott
Admin
I do stuff.Sam_Hall
Jun 20, 2019I'd be happy to send someone some screen captures to someone from f5, or if you have a good tool for measuring performance and want me to run some tests. To view this comment, the page took 25 seconds to load according to a page load timer browser extension. But then it was just a white screen with the logo for probably another 25 seconds after that for example. I'm really not exaggerating some of those load times I've mentioned above.
