Practical considerations for using Azure internal load balancer and BIG-IP
Background
I recently had a scenario that required me to do some testing and I thought it would be a good opportunity to share. A user told me that he wants to put BIG-IP in Azure, but he has a few...
Updated Feb 12, 2024
Version 4.0MichaelOLeary
Employee
I'm a Solution Architect at F5. Over the years I've become an expert in Kubernetes and cloud architectures. I publish articles and blog posts to share as much knowledge as possible. I love hanging out with customers and co-workers, so reach out any time!raviraj
Altostratus
Jan 01, 2024Thank you for explaination. Do you have any sample configuration for above topology. I have following queries or doubts. Sorry if I am asking wrong queries.
- If Virtual IPs are different than external Interfaces of F5 LB then as per my understanding it needs to be configured on F5 LB, then what frontend IPs we need to configure on Azure ILB when traffic destined for Virtual IPs.
- If front-end IP of Azure ILB is 10.0.2.50 and external interfaces of F5 LB are within this Subnet 10.0.2.0/24 and if Virtual IPs are different then how to configure load balancing rule in Azure ILB.
- Usually for inbound traffic, on Azure ILB we need to configure different rules for Front-end IP with port. For example we have two ports 80 & 443 then I am not sure how one inbound rule will be sufficent for these ports.
