Practical considerations for using Azure internal load balancer and BIG-IP
Background
I recently had a scenario that required me to do some testing and I thought it would be a good opportunity to share. A user told me that he wants to put BIG-IP in Azure, but he has a few...
Updated Feb 12, 2024
Version 4.0MichaelOLeary
Employee
I'm a Solution Architect at F5. Over the years I've become an expert in Kubernetes and cloud architectures. I publish articles and blog posts to share as much knowledge as possible. I love hanging out with customers and co-workers, so reach out any time!MichaelOLeary
Employee
Dec 25, 2023Hi ChrisGordon
I'm just seeing your comment now, so I'm so sorry I have not replied before now. If you still need help, shoot me a message via this website. Otherwise, if you have 0 statistics on your F5 BIG-IP statistics tab, double-check that the "Enable IP Forwarding" checkbox is disabled on your NIC in Azure. If you have enabled "Floating IP" on the Azure LB, then it does not perform destination NAT. Because of this, you must configure Azure to allow traffic to the BIG-IP where the Layer 3 Destination IP address does not match the IPconfiguration on the NIC.
Thanks for reading!
Mike
