Practical considerations for using Azure internal load balancer and BIG-IP
Background
I recently had a scenario that required me to do some testing and I thought it would be a good opportunity to share. A user told me that he wants to put BIG-IP in Azure, but he has a few...
Updated Feb 12, 2024
Version 4.0MichaelOLeary
Employee
I'm a Solution Architect at F5. Over the years I've become an expert in Kubernetes and cloud architectures. I publish articles and blog posts to share as much knowledge as possible. I love hanging out with colleagues and customers, so reach out any time!Sajid_Gul_Ambe1
Apr 19, 2020Dear Micheal,
I have test the Template and it is deployed successfully in my lab environment. Currently for testing purpose I have use PayAG template. Also I have deleted the External Load-Balancer, After deleting the external load balancer I was still able to access both BIGIPs via management Public IP.
As I have deleted the external Load-Balancer now it will look Like an option A right ?
for Option A you have mentioned source Nat is required I have confusion in which LB i have to Source NAT on F5 BIG or Azure LB ?
