Nikola_Tesla_19
Apr 28, 2015Hi Joe, Is it possible to use the iControl REST API if you are not in the Administrator role. I would like to use the API to check Pool Status by I keep getting '"code":401,"message":"Authorization failed: no user named svc-hpoo-tm found. ' This user works fine using SOAP....Thanks
