HTTPS SNI Monitoring How-to
You may or may not already have encountered a webserver that requires the SNI (Server Name Indication) extension in order to know which website it needs to serve you. It comes down to "if you ...
Published Mar 23, 2014
Version 1.0Thomas_Schocka1
Altocumulus
Joined May 04, 2012
John_Beckmann
Employee
Nov 19, 2018There seems to be a bug in the script if you try to set a HEADER
http_content=
(echo -e "$monitor_method $monitor_uri HTTP/1.1\r\nHost: $monitor_hostname\r\n${monitor_header}\r"; $sleep $monitor_stdin_sleeptime) | $openssl s_client -connect $monitor_targetip:$monitor_targetport -servername $monitor_hostname
After the ${monitor_header} there is only a \r but it should be \r\n
