F5 Sites
  • F5.com
  • F5 Labs
  • MyF5
  • NGINX
  • Partner Central
Contact
  • Under Attack?
  • F5 Support
  • DevCentral Support
  • F5 Sales
  • NGINX Sales
  • F5 Professional Services
Open Side Menu
Skip to contentBrand Logo
Forums
CrowdSRC
Articles
RegisterSign In
  1. DevCentral
  2. Articles
  3. Technical Articles
HTTPS SNI Monitoring How-to
Hi, You may or may not already have encountered a webserver that requires the SNI (Server Name Indication) extension in order to know which website it needs to serve you. It comes down to "if you ...
Published Mar 23, 2014
availability
deployment
https
management
monitor
monitoring
openssl
security
sni
ssl
Thomas_Schocka1's avatar
Thomas_Schocka1
View Profile
Opher_Shachar_6's avatar
Opher_Shachar_6
Oct 10, 2016
@daboochmeister It is about the TLS extension of Server Name. This happens at the SSL negotiation level that takes place before the HTTP request is sent. ADFS for example will reset the connection if no SNI extension is given in the SSL's ClientHello.
ABOUT DEVCENTRAL
RESOURCES
SUPPORT
PARTNERS
