HTTPS SNI Monitoring How-to
You may or may not already have encountered a webserver that requires the SNI (Server Name Indication) extension in order to know which website it needs to serve you. It comes down to "if you ...
Published Mar 23, 2014
Version 1.0Thomas_Schocka1
Altocumulus
Joined May 04, 2012
Thomas_Schocka1
Altocumulus
Mar 25, 2014Aaron,
Done.
There happens to be a question (which is actually a response) from somebody who encountered the same issue, but with ADFS. He also created an external script, and I find his method of calling openssl a lot 'prettier' than my (echo $something; sleep 5) | openssl ..... . I think I should maybe change my script to match his method - will test that.
Kind regards,
Thomas
