Deploy BIG-IP in AWS with HA across AZ’s - without using EIP’s
Background:
The CloudFormation templates that are provided and supported by F5 are an excellent resource for customers to deploy BIG-IP VE in AWS. Along with these templates, documentation guidi...
Published Feb 21, 2019
Version 1.0MichaelOLeary
Employee
I'm a Solution Architect at F5. Over the years I've become an expert in Kubernetes and cloud architectures. I publish articles and blog posts to share as much knowledge as possible. I love hanging out with colleagues and customers, so reach out any time!MichaelOLeary
Employee
Employee
Jun 23, 2020Hi Omar, you should choose "No, do not configure high availability across Availability Zones" from the field above and then you will not enter any EIP. I know this sounds counter-intuitive, but that field is assuming you will use EIP's. In this architecture discussed, we are not using EIP's.
Also - at this point you should really be using the Cloud Failover Extension (CFE) which was released about a year ago, and is mentioned in an update to the article above. The CFE allows you to declare a failover configuration as a JSON template, and that iApp is no longer the way to do it going forward into the future.
Feel free to email me or reach out directly if you need help.
