Big-IP and ADFS Part 5 – “Working with ADFS 3.0 and SNI”
Can you believe it? It’s true, it’s true! There’s a part 5. What can I say? Times change; people change; software changes. Active Directory Federation Services, (ADFS) is no exception. While the BIG-...
Published May 29, 2014
Version 1.0Greg_Coward
Employee
Joined July 19, 2011
DaleLeBlanc
Jun 13, 2022"If ADFS proxy server is configured to accept SSL/TLS connections only using TLSv1.1 or better , the monitor will not work."
My configuration only permits TLSv1.2. Is there a workaround?
