Big-IP and ADFS Part 5 – “Working with ADFS 3.0 and SNI”
Can you believe it? It’s true, it’s true! There’s a part 5. What can I say? Times change; people change; software changes. Active Directory Federation Services, (ADFS) is no exception. While the BIG-...
Published May 29, 2014
Version 1.0Greg_Coward
Employee
Joined July 19, 2011
rmd1023
May 02, 2017I think you'll need different scripts. So, for example, you'd have external monitor script "sni_monkey.sh" where the "HOST" command is hardcoded as "monkey.example.com", and another external monitor "sni_banana.sh" where "HOST" is hardcoded as "banana.example.com". The hardcoded URI would be the same in both scripts.
