Big-IP and ADFS Part 5 – “Working with ADFS 3.0 and SNI”
Can you believe it? It’s true, it’s true! There’s a part 5. What can I say? Times change; people change; software changes. Active Directory Federation Services, (ADFS) is no exception. While the BIG-...
Published May 29, 2014
Version 1.0Greg_Coward
Employee
Joined July 19, 2011
dav_103788
Aug 12, 2016I could make it work on BIG-IP 11.5.3 Build 2.0.196 Hotfix HF2. Don't know why but, as soon as the script is updated through the GUI ( with or without modification ), the script appears in the directory /tmp and the check is OK, before ( just after uploading the script and creating the monitor ) I could not find it on the disk and the check was KO.
I have also tested with or without the "()", it works in both cases.
