Big-IP and ADFS Part 5 – “Working with ADFS 3.0 and SNI”
Can you believe it? It’s true, it’s true! There’s a part 5. What can I say? Times change; people change; software changes. Active Directory Federation Services, (ADFS) is no exception. While the BIG-...
Published May 29, 2014
Version 1.0Greg_Coward
Employee
Joined July 19, 2011
MS_273769
Jul 19, 2016I removed the () before the echo and it worked for me.
echo -e "GET $URI HTTP/1.1\r\nHost: $HOST\r\nConnection: Close\r\n\r\n"; sleep 2 | openssl s_client –quiet –servername $HOST -connect $NODE:$PORT 2> /dev/null| grep -i "$RECV" 2>&1> /dev/null
