Big-IP and ADFS Part 5 – “Working with ADFS 3.0 and SNI”
Can you believe it? It’s true, it’s true! There’s a part 5. What can I say? Times change; people change; software changes. Active Directory Federation Services, (ADFS) is no exception. While the BIG-...
Published May 29, 2014
Version 1.0Greg_Coward
Employee
Joined July 19, 2011
Renee
Mar 16, 2016Is there a reason to use /FederationMetadata/2007-06/FederationMetadata.xml as the URI value vs /adfs/fs/federationserverservice.asmx which is what is in the deployment guide? Both seem to work fine. Thanks
