APM Cookbook: Modify LDAP Attribute Values using iRulesLX
I'm getting some errors when trying this out. Have you seen this before?
info sdmd[7077]: 018e0017:6: pid[25600] plugin[/Common/ldap_modify_plugin.ldap_modify_extension] dn: null,attr: employeeID,val: $CK$yeY8fCTj$mf5momsvuPKFH7MHQFlJPA==
info sdmd[7077]: 018e0017:6: pid[25600] plugin[/Common/ldap_modify_plugin.ldap_modify_extension] Creating LDAP Client.
info sdmd[7077]: 018e0017:6: pid[25600] plugin[/Common/ldap_modify_plugin.ldap_modify_extension] LDAP Bind Successful.
err sdmd[7077]: 018e0018:3: pid[25600] plugin[/Common/ldap_modify_plugin.ldap_modify_extension] /var/sdm/plugin_store/plugins/:Common:ldap_modify_plugin_45236_4/extensions/ldap_modify_extension/node_modules/ldapjs/lib/dn.js:171
err sdmd[7077]: 018e0018:3: pid[25600] plugin[/Common/ldap_modify_plugin.ldap_modify_extension] throw new TypeError('name (string) required');
err sdmd[7077]: 018e0018:3: pid[25600] plugin[/Common/ldap_modify_plugin.ldap_modify_extension] ^
err sdmd[7077]: 018e0018:3: pid[25600] plugin[/Common/ldap_modify_plugin.ldap_modify_extension] TypeError: name (string) required
err sdmd[7077]: 018e0018:3: pid[25600] plugin[/Common/ldap_modify_plugin.ldap_modify_extension] at Object.parse (/var/sdm/plugin_store/plugins/:Common:ldap_modify_plugin_45236_4/extensions/ldap_modify_extension/node_modules/ldapjs/lib/dn.js:171:11)
info sdmd[7077]: 018e0017:6: pid[25600] plugin[/Common/ldap_modify_plugin.ldap_modify_extension] MPI.0 ilx:45687:1 size 2
info sdmd[7077]: 018e000f:6: Extension /Common/ldap_modify_plugin:ldap_modify_extension pid 25600 exited with status 1
info sdmd[7077]: 018e000b:6: Extension /Common/ldap_modify_plugin:ldap_modify_extension started, pid:25626
info sdmd[7077]: 018e000f:6: Extension Unknown Extension pid 25600 exited with status 1 err sdmd[7077]: 018e0011:3: Received sigchld for unknown pid 25600
Br Andréas
