APM Cookbook: Modify LDAP Attribute Values using iRulesLX
Introduction
Access Policy Manager (APM) does not have the ability to modify LDAP attribute values using the native features of the product. In the past I’ve used some creative unsupported solutio...
Published Sep 27, 2016
Version 1.0Smithy
Joined July 31, 2011
gregan_306943
May 03, 2017Hi Brett,
When installing ldapjs i'm getting errors returned in the cli.
Active:In Sync] irule_ldap_extension npm install ldapjs -save npm ERR! Linux 2.6.32-431.56.1.el6. npm ERR! argv "/usr/bin/node" "/usr/bin/.npm__" "install" "ldapjs" "-save" npm ERR! node v0.12.15 npm ERR! npm v2.15.1 npm ERR! code EAI_AGAIN npm ERR! errno EAI_AGAIN npm ERR! syscall getaddrinfo
npm ERR! getaddrinfo EAI_AGAIN npm ERR! npm ERR! If you need help, you may report this error at: npm ERR! https://github.com/npm/npm/issues
