Upload small files (certs/keys/etc) to BIG-IP via iControl REST (base64 encoded using cli script)
Problem this snippet solves:
I had a need to upload SSL certificates and keys to the BIG-IP in a simple manner that was fast. I did so by creating a cli script that would accept a filename, base64 encoded file and the file type (ascii/binary), then would write out the file to disk.
How to use this snippet:
curl -sk -u username:password -X POST -H 'Content-Type: application/json' https://PRIMARY_F5/mgmt/tm/cli/script -d '{"command":"run","utilCmdArgs":"file_creation [filename] [filetype] [file_base64encoded"}'
Code :
create cli script fileupload {
proc script::init {} {
proc script::run {} {
package require base64
set filename [lindex $tmsh::argv 1]
set filetype [lindex $tmsh::argv 2]
set contents [lindex $tmsh::argv 3]
if { [file exists $filename] == 0} {
if { $filetype == "binary"} {
set result [::base64::decode $contents]
set finalfile [open $filename "w"]
fconfigure $finalfile -encoding binary
puts -nonewline $finalfile [::base64::decode $contents]
close $finalfile
return 0
if { $filetype == "ascii"} {
close $finalfile
return 0
if { [file exists $filename] == 1} {
puts "File already exists"
error "File already exists"
return 1
proc script::help {} {
proc script::tabc {} {
total-signing-status not-all-signed
}Tested this on version:
12.1Published Aug 13, 2019
Version 1.0G-Rob
Employee
F5 Solutions Engineer focused on cloud, automation, modern apps and excellent customer-focused service.No CommentsBe the first to comment
