Update / Modify a Traffic Group of a Virtual Address using F5-SDK
Problem this snippet solves:
I have an Active-Active LTM Deployment.
Virtual Servers ( and Virtual Addresses ) are split between two units. I am trying to use F5-SDK to update traffic group so that VS/VA will move between two units.
How to use this snippet:
Environment
Python : 3.6 F5 SDK : 3.0.20 LTM : 12.1.2 HF2
Code :
from f5.bigip import ManagementRoot
import sys
# This will update a traffic group on a virtual address on the same bigip
# Vars
New_BigIP_IP = "10.10.10.10"
Virt_Addr = "192.168.13.151"
Traffic_Group = '/Common/traffic-group-2'
# Connect
f5_mgmt = ManagementRoot(New_BigIP_IP, username, password)
# load Virtual Address
v_a_info = f5_mgmt.tm.ltm.virtual_address_s.virtual_address.load(name=Virt_Addr,partition='Common')
# Verify if traffic group needs to be updated
if v_a_info.trafficGroup == Traffic_Group:
print ("Traffic groups are same - no need to update - \nexiting ... ")
sys.exit()
#Capture the Old Traffic Group
Old_Traffic_Group = v_a_info.trafficGroup
print("\nOld Traffic Group : {} \nNew Traffic Group:}".format(Old_Traffic_Group,Traffic_Group))
input("Press any key to Continue.. ")
# Update the New Traffic Group
v_a_info.modify(trafficGroup=Traffic_Group)
print ("== Traffic Group has been updated ==\n")Tested this on version:
12.1Updated Jun 05, 2023
Version 2.0Muhammad_64435
Joined January 04, 2011
2 Comments
- Muhammad_64435
I have enhanced the above code that will allow you to change a traffic group to any or all Virtual Addresses on a LTM unit.
- Muhammad_64435
from f5.bigip import ManagementRoot import sys from random import randrange from pprint import pprint This module will read all the Virtual Servers from the bigip unit and create a dictionary e.g; VIP-name, IP address and Traffic-Group assigned VIPs_dict = { 'vs-client1.company.com-http':'['192.168.12.100','Traffic-group-1'], 'vs-consumer.company.com-https':'['192.168.12.200','Traffic-group-1'], .... } Contributor : mshoaib@paciolan.com Environment Python : 3.6 F5 SDK : 3.0.20 LTM : 12.1.2 HF2 Requirements : 1. Create a folder name "data" in the same directory where this script will run. It will be used to save the current config 2. Update the Variables section below according to your environment def save_traffic_group_config(traffic_group_config): ''' This function will save the current traffic groups config to a file ''' This will create a file name "traffic_group_config_" new_file = open("data/traffic_group_conifg_"+str(randrange(1000)),'w') new_file.write("\n{}\t{}\t{}".format('Virtual','IP','Traffic Group')) for key in traffic_group_config.keys(): new_file.write("\n{}\t{}\t{}".format(key,traffic_group_config[key][0],traffic_group_config[key][1])) new_file.close() print ("\nCurrent Virtual Addresses Traffic Group config have been saved ....") ------ def modify_traffic_group(virtual_server_name,virtual_address,bigip_mgmt): ''' This function will take a name of virtual server and switch its traffic group from 1 to 2 OR 2 to 1 Assumption : You have two traffic group named a) traffic-group-1 b) traffic-group-2 ''' Load a Virtual Address virt_address_info = bigip_mgmt.tm.ltm.virtual_address_s.virtual_address.load(name=virtual_address, partition='Common') print ("{} traffic group is {}".format(virtual_server_name,virt_address_info.trafficGroup)) response = input("Type Y or yes to Change or to Skip ... ") User Input to proceed if response.lower() == 'yes' or response.lower() == 'y': print (" Traffic Group Changed ") else: print (" No Change ") return if virt_address_info.trafficGroup == "/Common/traffic-group-1": new_TG = "/Common/traffic-group-2" else: new_TG = "/Common/traffic-group-1" Update the Traffic Group for that particular virtual server name / virtual address virt_address_info.modify(trafficGroup=new_TG) Variable Section BigIP = "BigIP" BigIP_username = "admin" BigIP_password = "admin" cur_virtuals_info = {} Empty dict to collect Virtual Server Name, IP address & Traffic Group tmp_virtual_address = [] it will store the IP of Virtual Addresses and help to avoid duplicates Connect to BigIP f5_mgmt = ManagementRoot(BigIP, BigIP_username, BigIP_password) Gather Virtual Address and Virtual Server info virt_addrs = f5_mgmt.tm.ltm.virtual_address_s.get_collection() virt_srvs = f5_mgmt.tm.ltm.virtuals.get_collection() Fill up the Current Virtuals info for v_s in virt_srvs: for v_a in virt_addrs: Compare Virtual Server IP and Virtual Address ( also an IP ) and if same then grab the traffic group and feed into the dict if v_a.name == v_s.destination.split('/')[2].split(':')[0]: Match the IP address if len (cur_virtuals_info) == 0: Enter the first value in as is cur_virtuals_info[v_s.name] = [v_s.destination.split('/')[2].split(':')[0],v_a.trafficGroup.split('/')[2]] save the virtual address in tmp list to compare and avoid duplicates tmp_virtual_address.append(v_s.destination.split('/')[2].split(':')[0]) continue else: Check if virtual address already exisit, if yes then skip if v_s.destination.split('/')[2].split(':')[0] in tmp_virtual_address: Virtual address already inserted, skip insertion continue else: Insert the Virtual Server / Address into the dict and in the temp list for comparison cur_virtuals_info[v_s.name] = [v_s.destination.split('/')[2].split(':')[0],v_a.trafficGroup.split('/')[2]] tmp_virtual_address.append(v_s.destination.split('/')[2].split(':')[0]) continue Save the current Config save_traffic_group_config(cur_virtuals_info) for k in cur_virtuals_info.keys(): modify_traffic_group(k,cur_virtuals_info[k][0],f5_mgmt)
