Python module to post and retrieve IControl Rest JSON objects for AVR statistics
Problem this snippet solves:
This module simplifies making Python dictionary objects that are converted to IControl rest AVR JSON objects. It also handles making AVR requests and retrieving results as well allowing multiple AVR requests to be queued, posted and retrieved. It also has some basis type checking for the elements of a AVR request. This module requires Bigip 12.1 on the target that statistics are retrieved.
How to use this snippet:
The main class is rest_avr.avr_req. It is a dictionary class that maps directly to an IControl Rest AVR JSON request as translated by json.dumps. Each dictionary element is an object derived from a customer class for each part of the request. The element classes have add() and clear() functions. if the element class only allows one entry the add() function will replace the existing entry, otherwise it will append the entry to the request element. The rest_avr.avr_req class also has functions to populate the HTTP host and authentication values for the target system.
rest_avr.avr_req.post_and_response
returns the Python representation of the JSON result of the query.
rest_avr.avr_req.add_to_queue()
adds the currently constructed request to a queue of requests to post.
rest_avr.avr_req.post_and_response_queue()
returns a python list of results of queued queries.
The following code sample constructs, posts and returns results for an AVR statistics request for specific DNS records and a specificrecord type, then queues multiple quests and posts and returns results.
#!/usr/bin/python
import json
import sys
import time
import rest_avr
#print rest_avr.ShowAVRJsonApi
#Populate the url
avr_dns_req=rest_avr.avr_req()
avr_dns_req.auth('admin','admin')
avr_dns_req.url_base('10.10.2.113','dns')
#Populate the json object
avr_dns_req['analyticsModule'].add('dns')
avr_dns_req['reportFeatures'].add('time-aggregated')
avr_dns_req['entityFilters'].add('domain-name', 'OPERATOR_TYPE_EQUAL', ['test2.test1.com','test1.test1.com'])
avr_dns_req['entityFilters'].add('query-type', 'OPERATOR_TYPE_EQUAL', ['a'])
avr_dns_req['viewMetrics'].add('packets')
avr_dns_req['viewDimensions'].add('domain-name')
avr_dns_req['metricFilters'].add('packets', 'OPERATOR_TYPE_GREATER_THAN', 0)
avr_dns_req['sortByMetrics'].add('packets', 'ascending')
avr_dns_req['pagination'].add(20, 0)
avr_dns_req['timeRange'].add(1461778251000000, None)
#Post and retrieve results.
result_py=avr_dns_req.post_and_response()
if result_py !=  None:
   print ('\n' + result_py['results']['timeAggregated'][0]['dimensions'][0]['value'] + " " + result_py['results']['timeAggregated'][0]['metricValues'][0]['value'] + '\n')
else:
   print result_py.error_layer
   print result_py.error_code
   print result_py.error_text
# Now add multiple requests to a queue
avr_dns_req.add_to_queue()
avr_dns_req['entityFilters'].clear()
avr_dns_req['entityFilters'].add('query-type', 'OPERATOR_TYPE_EQUAL', ['aaaa'])
#post and retrieve queued results
result_py_q=avr_dns_req.post_and_response_queue()
for result_py in result_py_q:
   else:
Code :
rest_avr provides a python interface to Bigip AVR statistics using the REST API. The main Python rest_avr.avr_req
object is a Python dictionary that  maps to a JSON object that can be processed with the json.dumps() function
An IControl Rest AVR JSON request and response can be initiated with avr_req.post_and_response
The simple description of the API can is available at avr_req.ShowJsonApi()
Each of these modules has a method to add single or multiple elements as appropriate to the specific module.
Once these elements are are populated a RestAPI request can be made with results returned as a python
representation.
avr_req.auth(user, passw)
avr_req.url_base(host, module)
avr_req['analyticsModule'].add(module)
avr_req['analyticsModule'].clear()
avr_req['reportFeatures'].add(metric_name, predicate, value)
avr_req['reportFeatures'].clear()
avr_req['entityFilters'].add(dimension_name, predicate, values)
avr_req['entityFilters'].clear()
avr_req['viewMetrics'].add(metric_name)
avr_req['viewMetrics'].clear()
avr_req['viewDimensions'].add(metric_name, order)
avr_req['viewDimensions'].clear()
avr_req['metricFilters'].add(metric_name, predicate, valu)
avr_req['metricFilters'].clear()
avr_req['sortByMetrics'].add(metric_name, orde)
avr_req['sortByMetrics'].clear()
avr_req['pagination'].add(num_results, skip_result)
avr_req['pagination'].clear()
avr_req['timeRange'].add(t_from, t_to)
avr_req['timeRange'].clear()
After a request in constructed a REST API call is initiated with initiated with:
avr_req.post_and_response()
The response is a python dictionary data structure  of the results as processed by json.loads
from copy import deepcopy
import requests
import json
import sys
import time
import warnings
__author__ = 'Mark Lloyd'
__version__ = '1.0'
# 05/24/2016
import json
import requests
import time
class BadDictElement(Exception):
    def __init__(self, key, value, expl):
        Exception.__init__(self, '{0} {1} {2} '.format(key, value, expl))
class BadTime(Exception):
    def __init__(self, variable, value):
        Exception.__init__(self, '{0} {1} should be 16 char decimal in microseconds '.format('a', 'b'))
class RequestFailure(Exception):
    def __init__(self, key, value):
        Exception.__init__(self, '{0} {1} '.format(key, value))
class analyticsModule(str):
    This class is tied to the structure of the parent class.
    parent() get's the parent object so we can make the string pseudo-mutable.
    accessed from within an avr request
    Adds a single string to analyticsModule element . If one exists it is replaced.
    Send a null value to the analyticsModule element.
    See rest_avr.ShowAVRJsonApi for more details
    def parent(self, parent):
        self.parent = parent
    def add(self, module):
        avr_req.['analyticsModule'].add(module)
        Adds a single string to analyticsModule element . If one already exists it is replaced.
        This should be the same as the  module string in avr_req.url_base.
        self.parent['analyticsModule'] = analyticsModule(module)
        self.parent['analyticsModule'].parent = self.parent
    def clear(self):
        replaces the analyticsModule mddule with a null string
        self.parent['analyticsModule'] = analyticsModule('')
class metricFilters(list):
    avr_req.['metricFilters'].add(metric_name, predicate, value)
    metric name is a string, value is an integer
    Valid predicates strings are  ['OPERATOR_TYPE_EQUAL', 'OPERATOR_TYPE_NOT_EQUAL', 'OPERATOR_TYPE_GREATER_THAN',
    OPERATOR_TYPE_LOWER_THAN','OPERATOR_TYPE_GREATER_THAN_OR_EQUAL', 'OPERATOR_TYPE_LOWER_THAN_OR_EQUAL'])
    Clears metricFilters elements
    See rest_avr.ShowAVRJsonApi for more details.
    def __init__(self):
        self.append([])
        self.valid_metric_predicate = (
            ['OPERATOR_TYPE_EQUAL', 'OPERATOR_TYPE_NOT_EQUAL', 'OPERATOR_TYPE_GREATER_THAN', 'OPERATOR_TYPE_LOWER_THAN',
    def add(self, metric_name, predicate, value):
        if type(value) is not int:
            raise BadDictElement(metric_name, value, 'value should be integer')
        if predicate in self.valid_metric_predicate:
            # first check if it is already there
            for metric in self[0]:
                if metric['metricName'] == metric_name:
                    metric['predicate'] = predicate
                    metric['value'] = value
                    return 0
                    # if it is not there then just add it.
            self[0].append({'metricName': metric_name, 'predicate': predicate, 'value': value})
        else:
            raise BadDictElement(metric_name, predicate, 'invalid predicate')
    def clear(self):
        del self[0][:]
class entityFilters(list):
    avr_req.['entityFilters'].add(dimension_name, predicate, values):
    All values are strings
    valid predicate is 'OPERATOR_TYPE_EQUAL'
    Clears the entityFilters element
    See rest_avr.ShowJsonApi for more details
    def __init__(self):
        self.append([])
    def add(self, dimension_name, predicate, values):
        if predicate is 'OPERATOR_TYPE_EQUAL':
            # then loop throuth to see if the dimenson name already exists, if so replace
            for entity in self[0]:
                if entity['dimensionName'] == dimension_name:
                    entity['predicate'] = predicate
                    entity['values'] = values
                    return 0
            self[0].append({'dimensionName': dimension_name, 'predicate': predicate, 'values': values})
        else:
            raise BadDictElement(dimension_name, predicate, 'predicate must be OPERATOR_TYPE_EQUAL')
    def clear(self):
        del self[0][:]
class reportFeatures(list):
    avr_req.['reportFeatures'].add( feature)
    adds report feature string. Multiple features are permitted.
    Clears the analyticsModule element.
    def add(self, feature):
        if feature not in self:
            self.append(feature)
    def clear(self):
        del self[:]
class sortByMetrics(list):
    avr_req.['sortByMetrics'].add(metric_name, order)
    valid order names are 'ascending' and 'descending'
    sortByMetrics is optional in an AVR request.
    Clears the sortByMetrics element.
    def __init__(self):
        self.metric_list = []
    def add(self, metric_name, order):
        if metric_name not in self.metric_list:
            self.append({'metricName': metric_name, 'order': order})
            self.metric_list.append(metric_name)
    def clear(self):
        del self[:]
        del self.metric_list[:]
class viewDimensions(list):
    avr_req.['viewDimensions'].add(dimension_name):
    adds view dimension, only one dimension is allowed
    add will replace element if it already exists
    Clears the viewDimensions element.
    def __init__(self):
        self.append([])
        self[0] = {}
    def add(self, dimension_name):
        adds view dimension string, only one dimension is allowed
        self[0]['dimensionName'] = dimension_name
    def clear(self, dimension_name):
        del self[0][:]
class viewMetrics(list):
    avr_req.['viewMetrics'].add(metric_name):
    appends metric_name string to list. The specification
    allows multiple view metric elements
    Clears the viewMetrics elements
    def __init__(self):
    def add(self, metric_name):
        allows multiple viewMetric elements
            self.append({'metricName': metric_name})
    def clear(self):
        del self[:]
class timeRange(dict):
    avr_req.['timeRange'].add( t_from, t_to)
    both values are 16 digit numeric value in microseconds
    of unix/linux time. t_to is optional and can be replace by None
    timeRange is an optional.
    Clears the timeRange elements
    def add(self, t_from, t_to):
        timeRange is optional.
        if type(t_from) is long and len(str(t_from)) == 16:
            self['from'] = t_from
        else:
            raise BadTime(t_from + " is 16 digit numeric value in microseconds")
        if t_to != '' and t_to != 0 and t_to != None:
            if type(t_to) is long and len(str(t_from)) == 16:
                self['to'] = t_to
            else:
                raise BadTime(t_to + " is 16 digit numeric value in microseconds")
        else:
            if 'to' in self.keys():
                del self['to']
    def clear(self):
        del self[:]
class pagination(dict):
    avr_req.['pagination'].add(num_results, skip_results)
    both are integer values.
    Clears the pagination elements
    def add(self, num_results, skip_results):
        both arguments are integers.
        if type(num_results) is int:
            self['numberOfResults'] = num_results
        else:
            raise BadDictElement('number of Results ', num_results, 'must be integer')
        if type(skip_results) is int:
            self['skipResults'] = skip_results
        else:
            raise BadDictElement('skipResults ', skip_results, 'must be integer')
    def clear(self):
        del self[:]
class avr_resp(dict):
    python response error is applicable.
    def __init__(self):
        self.error_layer = None
        self.error_code = None
        self.error_text = None
class avr_req(dict):
    The main class for rest_avr.
    avr_req contains a dictionary that maps to the elements of a Icontrol REST AVR request along with capability of
    posting that  request and receiving a response.
    The dictionary values are object instances of python classes that correspond to the the JSON values of the
     object's name/value pair.
    Each value has two public methods:
    avr_req.['objectName']add():  adds an element to the appropriate object with type checking.
           If an element allows more then one instance the add function will append the element
           If an element allows only one instance the add function will replace the element
    avr_req.['objectName'].clear()r: clears all elements in the object.
    printing rest_avr.ShowAVRJsonApi provides documentation for the AVR JASON elements. Further documentation is
    available on devcentral.f5.com
    To post an AVR Rest request there are two functions to populate the HTTP/HTTPS request.
    avr_req.auth(user, passw):
        provides the username and password
        provides the host and the bigip module AVR queries to construct the URL to make the request.
    Then to post the request and return results in a python representation of the JSON response.
    def __init__(self):
        self['analyticsModule'] = analyticsModule()
        self['analyticsModule'].parent = self
        self['pagination'] = pagination()
        self['metricFilters'] = metricFilters()
        self['entityFilters'] = entityFilters()
        self['reportFeatures'] = reportFeatures()
        self['sortByMetrics'] = sortByMetrics()
        self['viewDimensions'] = viewDimensions()
        self['viewMetrics'] = viewMetrics()
        self['timeRange'] = timeRange()
        self.avr_session = requests.session()
        self.avr_session.verify = False
        self.avr_session.headers.update({'Content-Type': 'application/json'})
        # for multiple queued request handling.
        self.req_queue = []
        self.generate_id = None
        self.done = None
        self.result = None
        self.num_requests = 0
        self.res_queue = []
    def post_and_response(self):
        returns a python representation of the json response to the request.
        failure returns array ['ERROR','component',error]
        warnings.filterwarnings("ignore")
        self.generate_request = self.avr_session.post(self.req_url_base + "/generate-report/",
                                                      data=json.dumps(self))
        self.generate_request_py = json.loads(self.generate_request.text)
        self.result_guid = self.generate_request_py['id']
        self.results_status_url = self.req_url_base + "/generate-report/" + self.result_guid + "/?$select=status,reportResultsLink"
        self.results_url = self.req_url_base + "/report-results/" + self.result_guid
        self.sleeptime = .5
        for i in range(5):
            time.sleep(self.sleeptime)
            self.sleeptime *= 2  # double backoff period each time.
            self.status_results_json = self.avr_session.get(self.results_status_url)
            self.status_results = json.loads(self.status_results_json.text)
            if self.status_results['status'] == 'FAILED':
                self.result = avr_resp()
                self.result_error_layer = 'REST'
                self.result_error_code = self.status_results['status']
                self.result.error_text = self.status_results
            if self.status_results['status'] == 'FINISHED':
                self.raw_results_url = self.status_results['reportResultsLink']
                self.results_url = self.raw_results_url.replace('localhost', self.host_name)
                self.results = self.avr_session.get(self.results_url)
                if self.results.status_code == 200:
                    self.result.update(json.loads(self.results.text))
                    return self.result
                else:
                    self.result.error_layer = 'HTTP'
                    self.result.error_code = self.results.status_code
                    self.result.error_text = self.results
                    return self.result
            else:
                continue
        self.result.error_layer = 'REST_AVR'
        self.result.error_code = '408'
        self.result.error_text = 'TIMEOUT'
    def auth(self, user, passw):
        self.avr_session.auth = (user, passw)
    def url_base(self, host, module):
        host and  bigip module AVR queries to construct the URL to make the request.
        self.host_name = host
        self.req_url_base = 'https://%s/mgmt/tm/analytics/%s' % (host, module)
        self.module_py = {'analyticsModule': module}
    def add_to_queue(self):
        "adds request as currently constructed to queue"
        self.req_queue.append(deepcopy(self))
    def clear_queue(self):
        clears request queue
        del self.req_queue[:]
    def post_and_response_queue(self):
        posts and sends response to from queue of requests.
        for req in self.req_queue:
            req.generate_request = req.avr_session.post(req.req_url_base + "/generate-report/",
                                                        data=json.dumps(req))
            req.generate_request_py = json.loads(req.generate_request.text)
            req.generate_id = (req.generate_request_py['id'])
            req.results_status_url = self.req_url_base + "/generate-report/" + req.generate_id + "/?$select=status,reportResultsLink"
        self.sleeptime = .5
        self.num_requests = len(self.req_queue)
        for i in range(5):
                if req.done is None:
                    req.status_results_json = req.avr_session.get(req.results_status_url)
                    req.status_results = json.loads(req.status_results_json.text)
                    if req.status_results['status'] == 'FAILED':
                        req.result = avr_resp()
                        req.result_error['layer'] = 'REST'
                        req.result_error['error'] = req.status_results['status']
                        req.result_error['text'] = req.status_results
                    if req.status_results['status'] == 'FINISHED':
                        req.raw_results_url = req.status_results['reportResultsLink']
                        req.results_url = req.raw_results_url.replace('localhost', self.host_name)
                        req.results = self.avr_session.get(req.results_url)
                        if req.results.status_code == 200:
                            req.result.update(json.loads(req.results.text))
                            req.done = True
                            self.res_queue.append(req.result)
                            self.num_requests -= 1
                        else:
                            req.result_error.layer = 'HTTP'
                            req.result_error.code = req.results.status_code
                            req.result_error.text = req.results
                    if i == 5:
                        if req.result == False:
                            req.result.error_layer = 'REST_AVR'
                            req.result.error_error = '408'
                            req.result.error_text = 'TIMEOUT'
            if self.num_requests == 0:
                break
        return self.res_queue
ShowAVRJsonApi = """
reportFeatures
Specifies the kind of information that appears in a
response from AVR. You may specify one or more of the
following values:
existing-entities
time-aggregated
time-series
entities-count
viewDimensions
Specifies the dimensions for which to calculate a report,
such as:
{"dimensionName": "domain-name"}
You may only specify a single dimension. You may omit
this field in a report generation request.
viewMetrics
Specifies the list of metrics by which to sort results, such
as:
{ "metricName": "average-tps" },
{ "metricName": "transactions" }
If you specify either time-aggregated or
time-series features, you must specify one metric in
sortByMetrics
Specifies the list of metrics to sort by, such as:
[{ metricName: "average-tps", order:"descending" } ]
Valid values are ascending and descending. Sorting
only applies to the time-aggregated feature. You do
not need to specify this field in a report generation request.
timeRange
Specifies the time range, in microseconds, for which to
calculate a report, such as:
{"from": 1410420888000000, "to": 1410424488000000 }
You do not need to specify this field in a report generation
request.
entityFilters
Specifies the entities and values for which to calculate a
report. You can specify a single entity with a second level
of dimension filters that describe an aspect of the entity.
If you specify multiple entity types, the results include
only the entities that match all of the criteria. You do not
The following snippet contains two entities with
corresponding values:
"dimensionName" : "virtual",
"predicate": "OPERATOR_TYPE_EQUAL",
"values : ["phpAuction_VS_1"] },
"dimensionName : "response-code",
"values" : ["200"] }
metricFilters
Specifies the metric filters for which to calculate a report,
such as:
[{ "metricName": "transactions",
"predicate" :
metricFilters
"OPERATOR_TYPE_GREATER_THAN" "value":
100 }]
request. For the existing-entities feature, AVR
supports the OPERATOR_TYPE_LIKE predicate. AVR also
supports the following predicates:
OPERATOR_TYPE_EQUAL
pagination
Specifies the number of results to return, and the number
of results to skip, such as:
{ numberOfResults : 10, skipResults : 10}
To see the second set of ten results, use the example
shown here. AVR does not implement the OData query
parameters top or skip. In order to see a specific set of
results, you must set the number of results to return and
then determine how many results to skip. You do not need
Tested this on version:
12.0
Updated Jun 05, 2023
Version 2.0
1 Comment
  • Hi Mark_Lloyd,
    Could you please help me find the rest_avr library? Also, could you confirm whether the script is working correctly? I would really appreciate your assistance with this!
    Thank you!
