pyControl System Quick Audit
Problem this snippet solves:
This script gathers some basic but useful system information and prints it out.
You'll need to change the parameters to reflect your system(s). In this example our BigIP system is 192.168.1.245 with the default username and password info. See the syntax section below for example usage and sample output.
How to use this snippet:
Syntax
import pycontrol.pyControl as pc from pycontrol.samples.system_quick_audit import * from pycontrol.Utils import convert_uptime b = pc.BIGIP(hostname = 'your_system_ip_address', username = 'your_username', password = 'your_password', wsdl_files = ['System.SystemInfo']) get_basic_audit(b)
Sample Output
>>> get_basic_audit(b) =================================== System: lab-box.mylab.com Serial: bipXXXXXXs Product: 6400 (D63) Version: BIG-IP_v9.4.2 Uptime: 14 days, 21===================================
Code :
#!/bin/env python ''' ---------------------------------------------------------------------------- The contents of this file are subject to the "END USER LICENSE AGREEMENT FOR F5 Software Development Kit for iControl"; you may not use this file except in compliance with the License. The License is included in the iControl Software Development Kit. Software distributed under the License is distributed on an "AS IS" basis, WITHOUT WARRANTY OF ANY KIND, either express or implied. See the License for the specific language governing rights and limitations under the License. The Original Code is iControl Code and related documentation distributed by F5. The Initial Developer of the Original Code is F5 Networks, Inc. Seattle, WA, USA. Portions created by F5 are Copyright (C) 1996-2004 F5 Networks, Inc. All Rights Reserved. iControl (TM) is a registered trademark of F5 Networks, Inc. Alternatively, the contents of this file may be used under the terms of the GNU General Public License (the "GPL"), in which case the provisions of GPL are applicable instead of those above. If you wish to allow use of your version of this file only under the terms of the GPL and not to allow others to use your version of this file under the License, indicate your decision by deleting the provisions above and replace them with the notice and other provisions required by the GPL. If you do not delete the provisions above, a recipient may use your version of this file under either the License or the GPL. ---------------------------------------------------------------------------- ''' import pycontrol.pyControl as pyControl from pycontrol.Utils import convert_uptime ''' Perform a quick audit of basic system info. ''' def get_basic_audit(b): ''' get_basic_audit: gather some general info about a BigIP system. expects a valid, connected object as an argument. ''' #Create a convenience object s = b.System_SystemInfo #Get some basic info uptime = s.get_uptime()['return'] version = s.get_version()['return'] sysinfo = s.get_system_information() print "=" * 35 print "System: %s" % sysinfo['return']['host_name'] print "Serial: %s" % sysinfo['return']['chassis_serial'] print "Product: %s (%s)" % ( sysinfo['return']['product_category'], sysinfo['return']['platform'] ) print "Version: %s" % version print "Uptime: %s days, %s:%s:%s " % (convert_uptime(uptime)) print "=" * 35 if __name__ == "__main__": #Change the info below to reflect your system. b = pyControl.BIGIP(hostname = '192.168.1.245', username = 'admin', password = 'admin', wsdl_files = ['System.SystemInfo']) get_basic_audit(b)
Published Mar 09, 2015
Version 1.0CodeCentral_194
Joined May 04, 2019
