Periodic iCall script to auto-generate NodeIP-to-NodeName datagroup
Problem this snippet solves:
Hi Folks,
the iCall script and handler below can be used to auto-generate a NodeIP-to-NodeName datagroup on scheduled intervals. The auto-generate datagroup can then be used to resolve the
[LB::server addr] output to the coresponsing node name label using the [class match -value] syntax.
Cheers, Kai
How to use this snippet:
- Tweak the periodic intervals (in seconds) of the iCall handler as needed.
- Import the provided iCall script and handler using the tmsh load config merge from-terminal syntax
- Take a look to the configured data-groups and LTM logfiles to verify the results.
- Use
within an iRule to resolve the name of a selected pool member.[class match -value [LB::server addr] DG_IP_2_NODENAME]
Code :
sys icall script DataGroup_NodeIP_to_NodeName {
app-service none
definition {
set nodelist ""
set nodecounter 0
# tmsh::log "iCall: Starting to enumerate existing node objects..."
foreach partition [tmsh::get_config auth partition] {
set partition "/[tmsh::get_name $partition]"
# tmsh::log "iCall: Processing Partition: $partition"
tmsh::cd $partition
set nodes [tmsh::get_config /ltm node]
foreach node $nodes {
# tmsh::log "Processing Node : $partition/[tmsh::get_name $node]"
append nodelist "\"[tmsh::get_field_value $node "address"]\" \{ data \"[tmsh::get_name $node]\" \}\n"
incr nodecounter
# tmsh::log "Finished Partition: $partition"
tmsh::cd "/Common"
if { not ([tmsh::list /ltm data-group] contains "ltm data-group internal DG_IP_2_NODENAME") } then {
tmsh::log "iCall: Created the data-group \"DG_IP_2_NODENAME\"."
tmsh::create /ltm data-group internal "DG_IP_2_NODENAME" type "string"
# tmsh::log "iCall: The DataGroup does exist."
eval "tmsh::modify /ltm data-group internal DG_IP_2_NODENAME \{ records replace-all-with \{ $nodelist \} \}"
tmsh::log "iCall: Updated the data-group DG_IP_2_NODENAME with \"$nodecounter\" entries."
description none
events none
sys icall handler periodic DataGroup_NodeIP_to_NodeName {
first-occurrence 2016-09-12:00:00:00
interval 60
}Tested this on version:
12.0Updated Jun 05, 2023
Version 2.0Kai_Wilke
MVP
My name is Kai Wilke and I'm working as a Principal Consultant for IT-Security at itacs GmbH - a German consulting company specialized in Microsoft Security cloud solutions, F5 customizations as well as for classic IT-Consulting.
You can find additional information about me and my work here:
https://devcentral.f5.com/articles/q-a-with-itacs-gmbhs-kai-wilke-devcentrals-featured-member-for-february-248901 Comment
Was practicing trying to use this on 15.1.3.1 (in my lab) and running into this error:
Script (/Common/NodeList_2_Datagroup) generated this Tcl error: (script did not successfully complete: ("10.10.101.1" unknown propertyDon't know quite enough about iCall to diagnose, maybe Kai_Wilke could hook us up with a fix? 🙂
