F5 case creation tweaks
Problem this snippet solves:
Makes creating cases in the F5 portal a bit less of an head ache. This script uses Tampermonkey and BigIP-report as a data source to tailor make the case creation process according to your environment.
Features
Only show the modules you actually have activated:
Only show the installed versions
You can still see all of them if you need to
Select your loadbalancers from a dynamically populated drop-down menu
Other smaller things
- Configure default case severity
- Configure default choice for "Was this working before?"
- Configure default chose for "Is the problem related to a virtual server?"
- Configure a default peferred method of contact
- Configure a default time zone
How to use this snippet:
Instructions on how to use is available here
https://loadbalancing.se/2018/02/11/f5-case-creation-tweaks/#How_to_use
Code :
85493
- JustCooLpOOLe
Cirrocumulus
Thanks Patrick. I'll have to play around with it a little bit in a DEV area. We have an APM policy in front of the report so the authentication piece might be an issue.
Yeah, you should have the same DNS as your bigipreport. Instructions updated again, sorry for being unclear and thanks for feedback.
/Patrik
- JustCooLpOOLe
Cirrocumulus
Yes, I configured it. My bigipReprtURL is there. What should the value be for @connect? I have linuxworker.j.local. Should that be something else?
I have updated the instructions with one more step. Hope that helps...
/Patrik
Hi Shann
Did you configure the bigipreport URL?
/Patrik
- JustCooLpOOLe
Cirrocumulus
Hi Patrick,
I'm having trouble getting this to work. I copied and pasted Casecreation.js file into Tampermonkey and I can see it saved. When I do look at the script, this red X shows up for line 293.
for(var n in deviceNames)
The error says that 'n' is already defined. Could that be causing my issue?
You might be able to if you have a copy of the json file generated by BigIPReport. If you don't I might be able to make an update that supports a simple js object.
/Patrik
Could we set bigipReportURL to a local file?
Thanks Jason!
New version. Added feature: Now the script can handle if BigIPReport has failed to index individual devices.
- JRahm_128324Historic F5 Account
I love this!
